JuicyRevo Technik
    Feb 2008
    Manchester
    22
    Post Thanks / Like
    '99 A6 ABS light on. Controller not recognised.
    Hi guys,
    I have had the ABS light on the car for a while.
    When changing my alloys I found the front brake sensor wire had snapped, so I replaced the brake pads. I then tried to clear the fault.
    But vag.com or Bosch tool.
    Could not connect to the controller. No communication
    IS there any other way to clear this fault.
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    291
    Post Thanks / Like
    If neither tool can connect to the controller, check the fuse to the ABS controller, check the wiring to the controller, and then replace the controller. It would be helpful if you posted a full auto scan of the car so we would have full information. For instance, did the tools connect to any modules in the car? What version of VAG-COM were you running and what interface were you using?
    There are many possibilities to be considered. More information usually leads to better assistance.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    Feb 2007
    91
    Post Thanks / Like
    I had an ABS problem with the warning light showing and my local specialist's diagnosis software couldn't communicate with the ABS module. In virtually every case, he told me, this indicates a knackered ECU and sure enough that was the problem. BBA-Reman fixed my module for me for about £100.
    The OP may not care enough to reply to helpful posts in his thread, but perhaps other people searching on related matters (like me!) may find this useful in the future...
    2010 A6 Avant TDI S-Line LeMans
    1999 A6 Avant 2.5 TDI Quattro - gone, not forgotten.
    Jan 2004
    York
    1,639
    Post Thanks / Like
    My abs ecu is only £15
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=280274036588
    don't know if it'll fit a 99 A6
    Going ..... '56 Audi A4 2.0 TFSI Sline SE quattro Avant
    To be replaced by a
    11 plate SEAT Exeo CR ST Sport Tech
    Feb 2007
    91
    Post Thanks / Like
    Quote Originally Posted by auroan View Post
    That's completely different to the part that I had repaired by BBA-Reman.
    Jan 2004
    York
    1,639
    Post Thanks / Like
    Fair enough
    To be replaced by a
