JuicyUnicorn
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,412
    Post Thanks / Like
    Please help with codes..airbag.
    Skoda octavia 2003 airbag light is on,car had front damage now repaired,all parts were sourced from a donor vehicle and all parts including airbag control module was removed from donor vehicle (which had never been in a accident)
    seat belts were not replaced as they were ok.
    after vag plug in this is what i got
    p1636-3510 power train data busmissing message from airbag control module.
    01321 control module for airbag J234 any ideas?
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    291
    Post Thanks / Like
    Check the Ross-Tech Wiki: 01321
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    18,288
    Post Thanks / Like
    yeah sounds like a coding issue to me, was donor vehicle different as in saloon etc?
    Coding, Scanning, Installs, Parts, VCDS Seller
    "Live as if you were to die tomorrow, Learn as if you were to live forever"
    Aug 2006
    Magdeburg, Germany
    286
    Post Thanks / Like
    Not coding related at all, but since the codes posted by VW754 are once again incomplete nobody will be able to help. Post a complete Scan from the car, other than that I see no solution.
    Sebastian @ Ross-Tech.com
