DPMGNJ
Thread: Air Con Fault
    Aug 2006
    41
    Post Thanks / Like
    Air Con Fault
    I have a problem with my air con on my A3 8p i have run an auto scan with no faults found, but have had the car in to have it re gassed but they said that it was full of gas and the problem lies with either the compressor or the solonoid.
    Is there any way using vag com that i can investigate this problem or are there any fault codes that i should see.
    help would be appreciated on this one.
    Andy
    The Damned
    Apr 2007
    South Yorkshire
    339
    Post Thanks / Like
    Recently had a problem with my aircon too blowing out hot air, There is a test that you can doo with Vag-com if you have it? If not where abouts are you in the country?
    Out of interest when I posted the results from the Vag-com test on here nobody could shed any light on it as the system worked perfectly. Incidently it was down to a clutch/valve that was broken so nowt was getting through. Cost me £280! was was frustrating as originally I thought it needed regassing and had previously spent £80 doing so from Leeds Audi. Thought they would have checked it properly before handing it back to me
    Aug 2006
    41
    Post Thanks / Like
    i have vag com, do you know what test it is? and where i can find it on vag com
