KowalskiBadger5
Results 1 to 13 of 13
    347
    347's Avatar
    Sep 2006
    143
    Post Thanks / Like
    retro fitting hids
    as per title , i am planning on retro fitting the xeons to a 53 a3 2.0 tdi
    are there any vag com settings that i will need to change ?
    quattrojames's Avatar
    Mar 2008
    Dorset
    11,001
    Post Thanks / Like
    Are you thinking of a HID upgrade kit or actual xenon headlights?
    I fitted HID's to mine and they worked straight away with no need for vag-com. Also read a post earlier today from a user who fitted xenon headlights and they also worked from the off.
    2003 A4 Avant 2.5TDi quattro
    To do: Joey-mod headlights - Twin Exit Exhaust Conversion - Puddle light and Footwell light retrofit - Rear roof spoiler.
    WANTED: Unpainted standard front & rear lower valance (with twin exhaust cut outs) - from someone who's doing an S-Line upgrade.
    347
    347's Avatar
    Sep 2006
    143
    Post Thanks / Like
    hi , thanks for reply
    genuine audi hid headlights and genuine ballasts etc .
    so it sounds promising , thanks for your help
    Mar 2008
    Dorset
    11,001
    Post Thanks / Like
    http://audi-sport.net/vb/showthread.php?t=55462
    Check out the last post by Andyccr
    Where are you getting your headlights from? Have you checked out the legislation re headlight washers? Its a bit of a grey area but worth being aware of!
    h5djr's Avatar
    Cambs, UK
    5,293
    Post Thanks / Like
    Just be aware that fitting aftermarket HID units without the necessary auto-levelling and headlamps washers will make you car illegal in the eyes of the Department for Transport.
    For more detail see this link: http://www.dft.gov.uk/pgr/roadsafety/drs/hidheadlamps
    Dave R (h5djr)
    A3 8P3 2.0 TDI-170 Sportback SE S-tronic - Silver + loads of options - my 8th A3
    347
    347's Avatar
    Sep 2006
    143
    Post Thanks / Like
    fitted the hids today
    showing bulb failure warning , even though both hids work
    any ideas ?
    just to stop the critics
    i have used audi hid headlights
    audi ballasts and phillips oem bulbs
    I have also fitted my range control motors into the hid headlight so i have manual control of height should the need arise
    i wash car regularly and if i dont i make sure the lights are clean front and back , so no need for headlight wash
    not wishing to enter into an argument over any of the above
    there fitted and they are staying
    Mar 2008
    Dorset
    11,001
    Post Thanks / Like
    Sorry probably just me being dense again - do you mean you have fitted an HID upgrade kit or complete OEM xenon headlights?
    I have HID's and just electric levelling and no washers too and I'm not bothered, but I think the point h5djr was making was that technically in doing so the car is illegal. I have no intention of changing and as long as the lights are adjusted correctly there is no problem. But its good to be aware of these things!
    Have you had them properly adjusted since you fitted them?
    347
    347's Avatar
    Sep 2006
    143
    Post Thanks / Like
    it was not ment as a dig at anyone and all the technicalitys are understood , after all every post i have searched contains the same link from various people , but thanks anyway
    as far as my hid head lights are concered , yes they are complete audi oem headlights , minus the range control and washer system
    only roughly aligned , getting final adjustment tuesday morning , not planning on driving at night untill after then
    Oct 2003
    up north...
    767
    Post Thanks / Like
    have you coded the car properly - you may get motor adjuster failure notices which show on the dis as bulb failures
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    347
    347's Avatar
    Sep 2006
    143
    Post Thanks / Like
    no have only done a scan
    how do i check for correct coding
    Mar 2008
    Dorset
    11,001
    Post Thanks / Like
    Quote Originally Posted by 347 View Post
    Nice! Where did you get them from and what sort of cost where they if you don't mind me asking? And any joy with the bulb warning?
    347
    347's Avatar
    Sep 2006
    143
    Post Thanks / Like
    have had the n/s for about 6 months purchased from e bay , kept waiting for the o/s to turn up .
    used part search breaker link web site who located the o/s headlight
    all in they have come in around the £200 mark , not too bad for oem
    Mar 2008
    Dorset
    11,001
    Post Thanks / Like
    Can you post a close up pic of the headlight design please?
