Sky InsuranceAH Fabrications
    Feb 2007
    UK
    229
    Reset Adaption Values
    I believe by doing a Basic setting , 060, This will do a Throttle body align + reset adaption values.
    However after doing this, if i look at block 032 for the fuel adaption values, the idle is 0.0% but the part throttle is -4.7%.
    I expected it to reset these adaption values?
    Can someone please explain what the TBA actually resets, in means of adaption values.
    James
    Uwe@Ross-Tech's Avatar
    Oct 2006
    130
    If you want to reset the fuel trims to zero, clear fault codes (even if there are no fault codes).
    -Uwe-
    Feb 2007
    UK
    229
    Thanks!
    Not heard that method before!
    James
