Backdraft MotorsportKowalski
Results 1 to 17 of 17
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    Post Thanks / Like
    Boot unlocking problem
    Bit of a problem which I hope someone can help me with.
    At the moment I don't have selective unlocking enabled in vag com. When I unlock the car from the remote, all the doors unlock (front and rear) but the boot stays locked. I can't even open the boot from the latch button. I have to use the middle remote button and it's a real pain.
    The latch button is working fine as if I open the boot and press the button you can hear the mechanism working.
    I've tried enabling selective unlocking in vag com and that's not working either - it just unlocks all doors, no matter what the setting is in vag com.
    If I measure group 4 in channel 46 it shows the rear lid button as being non operational.
    What I'd like to happen is that when the car is unlocked from the remote, all the doors and boot are unlocked so I can open the boot from the latch button and not have to use the middle button on the remote all the time. Hoping someone can help me out as it's really doing my head in!!
    Jon
    Now A3 less......
    Uwe@Ross-Tech's Avatar
    Oct 2006
    130
    Post Thanks / Like
    Post up a scan from your car so we can see what modules are installed and how they are currently coded.
    -Uwe-
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    Post Thanks / Like
    Hi Uwe,
    As requested:
    VCDS Version: Beta 803.1
    Data version: 20080309
    Sunday,16,March,2008,14:05:24:56737
    Chassis Type: 1K0
    Scan: 01 03 04 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72
    VIN: WAUZZZ8P28A100672 Mileage: 9020km/5604miles
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door,Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 021 LG HW: 03G 906 021 AN
    Component: R4 2,0L EDC 000SG 9828
    Revision: --H07--- Serial number: AUX7Z0GNFN105J
    Coding: 0000072
    Shop #: WSC 66565 257 00032
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0023170
    Shop #: WSC 06314 000 00000
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG
    Component: KlimavollautomatH19 0420
    Revision: 210010 Serial number: 8P0820043AG
    Shop #: WSC 00000 000 00000
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
    Component: Bordnetz-SG H54 2501
    Revision: 00H54000 Serial number: 00000007817394
    Coding: F58A1F01B01410004F1600001600000000094E175A05000000 0000000000
    Shop #: WSC 06314 000 08192
    Part No: 8P2 955 119 E
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Part No: 4E0 910 557 B
    Component: REGENLICHTSENSORH13 0100
    Coding: 00150573
    Shop #: WSC 06314
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 L HW: 8P0 959 655 L
    Component: Airbag 9.41 H01 4210
    Revision: 91H01421 Serial number: 003CP001HYSY
    Coding: 0071612
    Address 16: Steering wheel Labels: 1K0-953-549.lbl
    Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
    Component: J0527 036 0070
    Coding: 0000012
    Address 17: Instruments Labels: 8P0-920-xxx-17.lbl
    Part No SW: 8P0 920 981 K HW: 8P0 920 981 K
    Component: KOMBIINSTR. VDO H20 0640
    Revision: D0H20001 Serial number: 224NG001101671
    Coding: 0004429
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 L HW: 1K0 907 951
    Component: J533__Gateway H15 0180
    Revision: H15 Serial number: 1400K07A310012
    Coding: E9817F064002020103
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D0H20001 Serial number: AUX7Z0GNFN105J
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 L HW: 8P0 035 192 L
    Component: RNS-E HIGH EU H74 0650
    Revision: 04S Serial number: AUZBZ7G0019665
    Coding: 0209113
    Shop #: WSC 44946 134 86300
    1 Fault Found:
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 101
    Mileage: 5320 km
    Time Indication: 0
    Date: 2008.02.15
    Time: 12:01:11
    Freeze Frame:
    Mileage: 5320 km
    Count: 1502
    Clock: 12:00
    Address 42: Door Elect, Driver Labels: None
    Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
    Component: Tuer-SG H03 0050
    Coding: 0004856
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 M
    Component: EPS_ZFLS Kl.079 H08 1901
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 J
    Component: KSG H11 0080
    Coding: 1800020000407F3F85054C9FC230
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    Address 52: Door Elect, Pass. Labels: None
    Part No SW: 8P0 959 802 J HW: 8P0 959 802 J
    Coding: 0004856
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 H
    Component: Dynamische LWR H01 0010
    Revision: 00000001 Serial number:
    Coding: 0000001
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0209113
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 101
    Mileage: 5320 km
    Time Indication: 0
    Date: 2008.02.15
    Time: 12:01:11
    Freeze Frame:
    Mileage: 5320 km
    Count: 1502
    Clock: 12:00
    Address 62: Door,Rear Left Labels: 8P4-959-801.lbl
    Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
    Component: Tuer-SG H04 0040
    Coding: 0000216
    Shop #: WSC 06314 000 1012544
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
    Coding: 0000216
    Jon
    Now A3 less......
    Oct 2006
    130
    Post Thanks / Like
    We're looking into it, stand by...
    -Uwe-
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    Post Thanks / Like
    Great - many thanks
    Jon
    Now A3 less......
    Aug 2006
    Magdeburg, Germany
    286
    Post Thanks / Like
    Went through your scan but the only thing related to your trunk lid problem could IMHO be the real lid security lock mentioned in the coding. As far I understand what you are saying, it could be the button/micro switch being faulty.
    Regarding the selective locking you are trying to enable, there are 3 instances where this can be enabled. The coding, the adaptation channels and last but not least the DIS menu in the instrument cluster.
    Sebastian @ Ross-Tech.com
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    Post Thanks / Like
    Thanks for the info Sebastian - I'll take a look at the security lock setting in the long coding and will go through the adaptation channels. Failing that it will mean a trip to the stealers I think.
    Will post back if i get anywhere.
    Jon
    Now A3 less......
    Aug 2006
    Magdeburg, Germany
    286
    Post Thanks / Like
    Ok, looking forward to your update.
    BTW: if you get a chance, could you do us a favor and send us a control module map from your front door control modules (#42 and #52)? Thanks.
    http://wiki.ross-tech.com/index.php/Control_Module_Maps
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    Post Thanks / Like
    Quote Originally Posted by Sebastian View Post
    Sure no problem - should get a chance Tues am.
    Jon
    Now A3 less......
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    Post Thanks / Like
    Quick update - selective unlocking is now working properly - I set it via the DIS (I didn't know you could do this - much easier!). Also looks like you can set the window convienience closing settings using the DIS as well.
    Will hook up vag-com tomorrow morning to see if I can sort the boot unlocking issue.
    Jon
    Now A3 less......
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    Post Thanks / Like
    Right, have disabled the security lid lock in the coding, and still the boot won't open unless I use the middle button on the remote - really weird.
    Will see if there is anything in the adaptation that might sort it at some point.
    Sebastian, link to the control module maps below as requested.
    Clicky
    Jon
    Now A3 less......
    Aug 2006
    Magdeburg, Germany
    286
    Post Thanks / Like
    Thanks for the heads up and the files. Don't think there is any related adaptation...
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    Post Thanks / Like
    You're right there isn't any adaptation
    Just a bit annoying that I can only use the middle button on the remote to open the boot - oh well, next time it's in at the stealers I'll get them to take a look.
    The micro switch works fine when the boot is open, just doesn't do anything when the boot is closed.
    Jon
    Now A3 less......
    Sep 2006
    32
    Post Thanks / Like
    Jon,
    I may be leading you astray,but I have been looking for a adapation code to "auto shut" my windows using 1 click on the remote(rather than holding the button) and came across this page:http://wiki.ross-tech.com/index.php/...fort_Functions
    It talks about matching buttons on the remote.
    Just a thought.
    Tony
    806
    Post Thanks / Like
    no tony i believe that is talking about synching a new remote to the car altogether not matching different buttons.
    Ben
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    Post Thanks / Like
    My car has been in to the dealer today and it was a coding issue that was causing the problem which is now fixed - hooray!
    I'll do another scan of the car when I get it back to show the new coding
    Jon
    Now A3 less......
    redbutcher's Avatar
    Aug 2007
    Northants
    657
    Post Thanks / Like
    Forgot to post the new coding which solved my problem:
    Coding: 1880202002186D0885054C8FC637
    Shop #: WSC 00443 210 91141
    Jon
    Now A3 less......
