Badger5EM Tuning
Results 1 to 7 of 7
    mattandrew's Avatar
    Sep 2007
    Up in the hills, Derbyshire
    958
    Post Thanks / Like
    Cruise control coding A3 8P
    I am in the process of fitting cruise to my 8P A3
    I have had a few problems still trying to sort
    ESP Fault, Steering Fault - Re Retro Fit Cruise! Help Please
    My question is what coding should be done?
    I have coded (16 Steering Wheel) 0011142 (auto, no multifunction, paddles, on board computer, cruise + rear wiper)
    Is there any other coding to be done, if so what else should be coded. The instruction book mentions engine control unit 001, but what do i need to change? Or are there any other modules to change.
    I am using full version 704 with the HEX-CAN cable
    Thanks in advance
    S3Ibis White
    Factory RNE-E : Optics : Light/rain sensor : ILP : BOSE : Bluetooth : iPod : Privacyglass : FCA : Auto Dimming/folding mirrors : Park assist
    Mods RS6 grill : Buckets : 19" Bentleys : KW v3 coilovers : H&R ARB's : Autotech HPFP : Milltek TBE : RS6 FBMFSW : Facelift taillights & diffuser : TT vents : ITG Intake : Forge DV : SDS : Alpine ipod kit : Lamin-X : Revo stage2+ : Sachs clutch : Shortended Tailgate : Ibis Colour Coded Interior
    To do FullClosureMirrors
    Vagcom
    Aug 2006
    Magdeburg, Germany
    286
    Post Thanks / Like
    What problems do you have exactly? Mind posting a COMPLETE Auto-Scan?
    Sebastian @ Ross-Tech.com
    mattandrew's Avatar
    Sep 2007
    958
    Post Thanks / Like
    If you have a look at the post i mentioned you will see what i have done as outlined on your website. Think i need to change the slip ring, as i can get everything functioning correctly with the old ECU apart from the cruise.
    Monday,25,February,2008,22:22:46:12592
    VAG-COM Version: Release 704.1
    Address 44: Steering Assist
    Control Module Part Number: 1K2 909 144 E
    Component and/or Version: EPS_ZFLS Kl.10 1202
    Software Coding: 0000000
    Work Shop Code: WSC 00000
    2 Faults Found:
    02546 - Steering Limit Stop
    005 - No or Incorrect Basic Setting / Adaptation - MIL ON
    Freeze Frame:
    Mileage: 5240 km
    Temperature: 20.0°C
    Voltage: 14.00 V
    Voltage: 13.90 V
    00778 - Steering Angle Sensor (G85)
    000 - - - MIL ON
    Freeze Frame:
    Mileage: 5240 km
    Count: 1
    Steering Angle: 0.00°
    Monday,25,February,2008,22:23:33:12592
    Address 03: ABS Brakes
    Control Module Part Number: 1K0 907 379 K
    Component and/or Version: ESP FRONT MK60 0103
    Software Coding: 0023174
    Work Shop Code: WSC 06435
    1 Fault Found:
    With the old ecu i can set the steering angle and stop etc but no cruise but with the new ECU i cant clear the errors or get cruise
    S3Ibis White
    Vagcom
    mattandrew's Avatar
    Sep 2007
    958
    Post Thanks / Like
    When I try to with the new ECU
    [Basic Settings - 04]
    Group 060
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    After a s
    Group 060
    [Go!]
    [ON/OFF/Next]
    After a successful basic setting, field 1 should say "OK".successful basic setting, field 1 should say "OK".
    I get "Not Ok" then "Not possible"
    Heres the full scan
    Data version: 20071016
    Monday,25,February,2008,22:38:33:12592
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 56 76 77 7D
    VIN: WAUZZZ8P54A114429 Mileage: 105260km/65405miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: None
    Part No SW: 03G 906 016 AT HW: 028 101 145 3
    Component: R4 2,0L EDC 0000AG 5689
    Coding: 0000078
    Shop #: WSC 66565
    No fault code found.
    Readiness: 0 0 1 1 1
    Address 02: Auto Trans Labels: 02E-300-0xx.LBL
    Part No SW: 02E 300 041 C HW: 02E 927 770 G
    Component: GSG DSG 0623
    Coding: 0000020
    Shop #: WSC 06435
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.LBL
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0023174
    Shop #: WSC 06435
    1 Fault Found:
    Address 08: Auto HVAC Labels: 8P0-820-043.LBL
    Part No SW: 8P0 820 043 E HW: 8P0 820 043 E
    Component: KlimavollautomatH12 0150
    Address 09: Cent. Elect. Labels: 8P0-907-279.LBL
    Part No SW: 8P0 907 279 D HW: 8P0 907 279 D*
    Component: Bordnetz-SG 1.0 H27 0601
    Coding: A588DF00A2141000000000000000000000
    Shop #: WSC 00000
    Part No: 8P2 955 119 A
    Component: Wischer WWS Audi350 0170
    Coding: 16711696
    Shop #: WSC 00000
    Address 15: Airbags Labels: 8P0-959-655-84.LBL
    Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
    Component: Airbag 8.4ED H00 0130
    Coding: 0011602
    Shop #: WSC 06435
    Address 16: Steering wheel Labels: 8P0-953-549-F.LBL
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0011142
    Shop #: WSC 12345
    Part No: XXXXXXXXXXX
    Component: E0221 H02 0030
    Address 17: Instruments Labels: 8P0-920-xxx-17.LBL
    Part No SW: 8P0 920 980 H HW: 8P0 920 980 H
    Component: KOMBIINSTR. VDO H25 0110
    Coding: 0000403
    Shop #: WSC 00557
    Address 19: CAN Gateway Labels: 1K0-907-530.LBL
    Part No SW: 1K0 907 530 B HW: 1K0 907 951
    Component: Gateway H08 0090
    Coding: 3F0F0FC8070101
    Shop #: WSC 06435
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.LBL
    Address 37: Navigation
    Cannot be reached
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.LBL
    Part No: 8P0 959 801 A
    Component: Tuersteuerger. H10 0010
    Coding: 0000120
    Shop #: WSC 06435
    Address 44: Steering Assist Labels: 1Kx-909-14x.LBL
    Part No: 1K2 909 144 E
    Component: EPS_ZFLS Kl.10 1202
    2 Faults Found:
    Freeze Frame:
    Mileage: 5240 km
    Temperature: 21.0°C
    Voltage: 13.90 V
    Voltage: 13.70 V
    000 - - - MIL ON
    Freeze Frame:
    Mileage: 5240 km
    Count: 1
    Address 46: Central Conv. Labels: 8P0-959-433.LBL
    Part No: 8P0 959 433
    Component: KSG H02 0040
    Coding: 188800186D288F0FC85AC65000
    Shop #: WSC 00340
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 1K0 907 719
    Component: Neigungssensor 002 0002
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0010
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.LBL
    Part No: 8P0 959 802 A
    Coding: 0000120
    Shop #: WSC 06435
    Address 56: Radio Labels: None
    Part No SW: 8P0 035 186 HW: 8P0 035 186
    Component: concert II EU H53 0060
    Coding: 0000231
    Shop #: WSC 06435
    Address 76: Park Assist Labels: 8P0-919-283.LBL
    Part No SW: 8P0 919 283 HW: 8P0 919 283
    Component: Parkhilfe 4-Kan H06 0020
    Coding: 0001003
    Shop #: WSC 06435
    Address 77: Telephone Labels: 8P0-862-335.LBL
    Part No SW: 8P0 862 335 K HW: 8P0 862 335 K
    Component: FSE_255x BT H26 0340
    Coding: 0000322
    Shop #: WSC 00000
    Address 7D: Aux. Heat Labels: 1K0-963-235.LBL
    Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
    Component: PTC-Element 0404
    End --------------------------------------------------------------------------------------------------
    S3Ibis White
    Vagcom
    Aug 2006
    Magdeburg, Germany
    286
    Post Thanks / Like
    What values (min/max) do you get for the sensor in the abs measuring blocks?
    mattandrew's Avatar
    Sep 2007
    958
    Post Thanks / Like
    i will go and have a look now and post back in 5 min
    What other coding do you normally have to do other than in the steering wheel 016.
    DO you have to do any in 001 or 019
    S3Ibis White
    Vagcom
    mattandrew's Avatar
    Sep 2007
    958
    Post Thanks / Like
    Sorted i hadnt coded the engine 01 with 11463
    S3Ibis White
    Vagcom
