hi Car drives perfectly then randomely EPC light will come on, first time this happened when car came to a stop would not go anywhere (no power) turn off then back on all good.
Has happened about 3 times since over a 2 week period, last time it happened came to a stop then tried to take off again car drove fine, didn't want to continue incase lost power while driving, pulled over turned off then back off all good. happened 3 more times of the way to work.
yesterday happened twice on the way to work about 45min drive, then for first time happened on the way home, first time it has happened in morning and night of the same day.
only happens when car is cold. no problems at all when car is warm!!
here are the vag com details, hope someone can point me in the right direction
VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 909 557 G
Component: 2.0L R4/5VS G 0003
Coding: 0004581
Shop #: WSC 31850
2 Faults Found:
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 001 - Upper Limit Exceeded
17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
P1171 - 008 - Implausible Signal - Intermittent
Readiness: 0010 0001
Address 03 -------------------------------------------------------
Controller: 8E0 614 517
Component: ABS/ESP front 1326
Coding: 04279
Shop #: WSC 06435
1 Fault Found:
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-10 - - - Intermittent
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 H
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC 63351
2 Faults Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-00 - Open or Short to B+
01794 - Control Module Incorrect Chassis (VIN) Number
35-00 - -
any help would be greatly appreciated.
thankyou
LinkBack URL
About LinkBacks
