Hi, recently run vagcom measuring blocks to check the maf and on 3 runs got a reading of 108g/s in 2nd gear on each run,my reading should be 120 g/s according to ross-tech fuel trim write up but does say if the reading is significantly lower it could be a maf problem but would you consider 108 g/s as being signifficantly lower than 120 g/s ?
Thanks in advance
Davec
Thanks in advance
Davec
