DTUKBadger5
Results 1 to 25 of 25
    tonycb6 is offline Neutral
    Sep 2006
    32
    Post Thanks / Like
    cruise control recode help
    Hi ,i have fitted cruise control to my 2006 A4 and all went well,coded the steering wheel ok,cleared all abs faults.But i am stuck trying to recode the last part
    To finish the job - go to module 01 - Engine
    Login
    Enter 11463
    Click on 'Do It'
    the login button is shaded out?
    Anyone able to help?
    Tony
    Google Adsense Circuit advertisement
    Issac Hunt is offline 5th Gear
    Jan 2007
    Hampshire
    1,150
    Post Thanks / Like
    What version of VAG-COM are you runnning? Do you have any problems connecting to other modules?
    A6 3.0 TDI.
    bearthebruce's Avatar
    bearthebruce is offline Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    277
    Post Thanks / Like
    The only product that will work with the 2006 A4 is VAG-COM version 704 and a HEX+CAN interface.
    How do I know? I drive one and I work for Ross-Tech.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    Sep 2006
    32
    Post Thanks / Like
    Yes i am using version 704 software and using a genuine HEX+CAN cable bought direct from ross tech by myself.
    When i was following the install instructons for the cruise control(audiretrofit.co.uk),the point at reseting the abs brakes ;
    [login-11]
    enter 40168
    [do it]
    I was unable to do that but I had to select "security access" then enter 40168.Which worked ok.
    Now,do I need to use the same way to enter 11463 for cruise?I may have used 40168 thinking this was the "security code" for my car and then it told me it was the wrong code and needs to "time out".
    If I press 07 coding it brings up the engine code in long code which i know nothing about but I did write it down....0104000318070020......
    I have not come accross any other problems accessing other modules,but then I have only used it to recode for sat nav so far on this car.
    Many thanks
    Tony
    Sep 2006
    32
    Post Thanks / Like
    All sorted had to use long code recoding adding "01"
    http://wiki.ross-tech.com/index.php/.../BWA%29#Coding
    Tony
    boggym is offline 1st Gear
    Dec 2007
    166
    Post Thanks / Like
    Hi Tony
    I've just retro fitted a cruise stalk to my 8P S3 and all went well, the steering wheel accepted the new code but I also can't access the Engine 01 - login 11 section, it's all greyed out. Could you explain how you managed to access it to input 11463.
    I'm using a fully registered version of vag-com so I should be able to access all sections!!
    Many Thanks
    Chris
    Jan 2007
    Hampshire
    1,150
    Post Thanks / Like
    You running version 704 or higher?
    A6 3.0 TDI.
    Sep 2006
    32
    Post Thanks / Like
    If you have ecu that require the long coding route to turn on criuse, we dont enter the 11463 code.You need to use the long codin route to do it,if you follow the
    http://wiki.ross-tech.com/index.php/.../BWA%29#Coding it will walk you through it.
    I had to use the recode in the long code section,my old code was ..0104000318070020.. I then read:
    I had to change to;0104000318070120
    Tony
    Dec 2007
    166
    Post Thanks / Like
    Cheers guys,
    Now I get where the "01" goes! I've just changed the long coding and tried it out on the road - everything works ok.
    Thanks again
    Chris
    Sep 2006
    32
    Post Thanks / Like
    Cool....No problem
    Tony
    MarcQuinlivan is offline 6th Gear
    Dec 2006
    Ireland
    2,538
    Post Thanks / Like
    I've just fitted a Cruise Control indicator stalk into a MKv GTi today and recoded the steering wheel from 0000012 to 0000042.
    Everything else on the stalk works as before (lights & indicators), but the cruise will not engage.
    Anybody know what else I need to be doing?
    I tried making the 00 to 01 long coding change mentioned above, but that seems to be for adaptive cruise control. 00 is for cruise control.
    I know it is not Audi, but it sohuld be something similar, shouldn't it.
    Sebastian is offline 1st Gear
    Aug 2006
    Magdeburg, Germany
    285
    Post Thanks / Like
    Quote Originally Posted by MarcQuinlivan View Post
    Post a complete Auto-Scan from the vehicle in question please.
    Sebastian @ Ross-Tech.com
    Dec 2006
    Ireland
    2,538
    Post Thanks / Like
    Thanks. It's my brother's car, so I won't seem him until probably the middle of the week to run the scan. I'll post the results as soon as I can.
    Dec 2006
    Ireland
    2,538
    Post Thanks / Like
    Quote Originally Posted by Sebastian View Post
    Sebastian,
    here is the full auto scan from the vehicle. It is a 2005 MkV Golf GTi.
    When I go into the 01 - Engine screen Coding II is greyed out.
    Sunday,08,June,2008,14:56:40:55747
    VCDS Version: Release 805.0
    Data version: 20080529
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZ5W182770 Mileage: 124880km/77596miles
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    62-Door,Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 1K0 907 115 HW: 1K0 907 115
    Component: 2.0l R4/4V TFSI 00 0070
    Revision: --H15--- Serial number: VWZ7Z0D1249607
    Coding: 0403000318070060
    Shop #: WSC 00896 210 92218
    No fault code found.
    Readiness: 0110 0101
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0104
    Coding: 0004738
    Shop #: WSC 01279 785 00200
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No: 1K0 820 047 EF
    Component: Climatic PQ35 084 0404
    Shop #: WSC 00000 000 00000
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
    Component: Bordnetz-SG H34 0803
    Revision: 00H34000 Serial number: 00000001323978
    Coding: E58D0F0600041800001400001400000000087F075C
    Part No: 1K2 955 119 B
    Component: Wischer VW350 012 0401
    Coding: 00065493
    Shop #: WSC 00000
    Part No: 1K0 955 559 M
    Component: RegenLichtSens 005 0605
    Coding: 00218142
    Shop #: WSC 00000
    3 Faults Found:
    01500 - Bulb for Fog-Lamps; Right (L23)
    007 - Short to Ground - Intermittent
    01049 - Supply Voltage Term 50
    006 - Short to Plus - Intermittent
    01496 - Bulb for Fog-Lamps; Left (L22)
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 C HW: 1K0 909 605 C
    Component: 08 AIRBAG VW8 013 2100
    Revision: 02013000 Serial number: 0033HD03RUEO
    Coding: 0012344
    Shop #: WSC 01269 785 00200
    Address 16: Steering wheel Labels: 1K0-953-549.lbl
    Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
    Component: Lenksäulenmodul 521 0050
    Coding: 0000042
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1K6 920 860 E
    Component: KOMBIINSTRUMENT VDD 0812
    Coding: 0003103
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 E HW: 1K0 907 951
    Component: Gateway H09 0110
    Revision: 09 Serial number: 2700104C140061
    Coding: 3D3F0340074003
    Shop #: WSC 00896 210 60936
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Component: IMMO VDD 0812
    Shop #: WSC 00896 210 89743
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
    Part No: 1K0 959 701 E
    Component: Tuersteuergeraet 09 0120
    Coding: 0000052
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 H
    Component: EPS_ZFLS Kl.12 1502
    Address 46: Central Conv. Labels: 1K0-959-433-46.lbl
    Part No: 1K0 959 433 BL
    Component: 01 KSG 0562
    Coding: 99C802087F2D8C0C085F018010
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
    Part No: 1K0 959 702 E
    Coding: 0000052
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 1K0 035 186 L
    Component: Radio BVX 012 0022
    Coding: 0040400
    1 Fault Found:
    00003 - Control Module
    014 - Defective
    Address 62: Door,Rear Left Labels: 1K0-959-703-GEN1.lbl
    Part No: 1K0 959 703 C
    Component: Tuersteuergeraet 06 0213
    Coding: 0000016
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
    Part No: 1K0 959 704 C
    Coding: 0000016
    Aug 2006
    Magdeburg, Germany
    285
    Post Thanks / Like
    Ok, your problem is as expected the engine control module coding (not Coding-2). The current coding 0403000318070060 has not been modified yet, the proper coding would be 0403000318070160. You can also use the long coding helper to make that change.
    Dec 2006
    Ireland
    2,538
    Post Thanks / Like
    Thanks Sebastian.
    I had that coding done last week when I installed the unit, and only set it back before generating that log file today. It was throwing an error and the cruise would not work with the 01 set.
    I'll use the long coding helper to set it back to 01 and generate another auto-scan.
    Once the 01 is set, is there anything else I need to do in order for it to work? Or should it just kick in at that point?
    Do I need to have the engine running or anything while making the change, and do I need to restart before it will pick it up?
    Aug 2006
    Magdeburg, Germany
    285
    Post Thanks / Like
    There shouldn't be anything else necessary, but would you mind elaborating what error you got exactly?
    Dec 2006
    Ireland
    2,538
    Post Thanks / Like
    Sebastian,
    here is the auto scan after setting the long coding to 01.
    Sunday,08,June,2008,16:39:39:55747
    Chassis Type: 1K0
    VIN: WVWZZZ1KZ5W182770 Mileage: 124950km/77640miles
    01-Engine -- Status: Malfunction 0010
    Component: 2.0l R4/4V TFSI G00 0070
    Coding: 0403000318070160
    1 Fault Found:
    001384 - Cruise Control Switch (E45): Implausible Signal
    P0568 - 002 - Lower Limit Exceeded
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 124958 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:37:18
    Freeze Frame:
    RPM: 850 /min
    Load: 27.0 %
    Speed: 0.0 km/h
    Temperature: 82.0°C
    Temperature: 53.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 13.589 V
    Coding: 0004738
    Coding: 00065493
    Shop #: WSC 00000
    Coding: 00218142
    Shop #: WSC 00000
    3 Faults Found:
    Coding: 0012344
    Coding: 0000042
    Coding: 0003103
    Coding: 0000052
    Coding: 0000052
    Coding: 0040400
    1 Fault Found:
    014 - Defective
    Coding: 0000016
    Coding: 0000016
    Dec 2006
    Ireland
    2,538
    Post Thanks / Like
    By the way, Cruise is still not working with 01 set.
    The error is:
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 124958 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:37:18
    Freeze Frame:
    RPM: 850 /min
    Load: 27.0 %
    Speed: 0.0 km/h
    Temperature: 82.0°C
    Temperature: 53.0°C
    Voltage: 13.589 V
    Dec 2006
    Ireland
    2,538
    Post Thanks / Like
    Sebastian,
    have you had time to look at the results of the auto-scan yet?
    Thanks.
    Aug 2006
    Magdeburg, Germany
    285
    Post Thanks / Like
    Sorry, didn't notice you had replied.
    Have you checked the special notes section in our WIKI regarding your fault code? I am very certain that this is your problem...
    http://wiki.ross-tech.com/index.php/16952/P0568/001384
    Dec 2006
    Ireland
    2,538
    Post Thanks / Like
    Thanks Sebastian.
    Do you know how I add this wire, or where I add it?
    Aug 2006
    Magdeburg, Germany
    285
    Post Thanks / Like
    As described here... but you should have gotten instructions with your ccs retrofitting kit.
    http://wiki.ross-tech.com/index.php/...trofitting_(1K)
    Dec 2006
    Ireland
    2,538
    Post Thanks / Like
    Thanks Sebastian.
    I ordered my stalk and lower column trim from VAGParts, but there were no instructions included.
    Dec 2006
    Ireland
    2,538
    Post Thanks / Like
    Just to let you know, I had the wheel off the car at the weekend and the signal wire (pin 13) is not in the steering wheel ECU connector.
