JBSAMD Technik
Thread: vag-com help
    Ballcrusher's Avatar
    Ballcrusher is offline NO CAT JUST 3" STRAIT THREW
    Jul 2006
    london
    343
    Post Thanks / Like
    vag-com help
    hello every one
    changed battery today and when i connected the new one this code come up as the abs light stayed on after starting the car
    http://i2.photobucket.com/albums/y8/...vagcomscan.jpg
    Google Adsense Circuit advertisement
    Advertising world
    NIGEL is offline Reverse Gear
    Jan 2007
    16
    Post Thanks / Like
    HI take car for test drive and check ABS works then clear fault with VAG COM. Take car for another test drive check ABS works then check for fault codes the ABS should not come up again however if it does check your ABS sensors.
