DTUKJBS
    mattandrew's Avatar
    mattandrew is offline 5th Gear
    Sep 2007
    Up in the hills, Derbyshire
    947
    Post Thanks / Like
    Parking assist fault
    Yesterday my A3 8P parking assist started playing up, When you put it un reverse you get a long beep then nothing. Manual states if you get this there is a fault.
    Just Vagcom check and get the following.
    Monday,28,January,2008,21:05:42:12592
    VAG-COM Version: Release 704.1
    Address 76: Park Assist
    Control Module Part Number: 8P0 919 283
    Component and/or Version: Parkhilfe 4-Kan H06 0020
    Software Coding: 0001003
    Work Shop Code: WSC 06435
    1 Fault Found:
    01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 3
    Fault Frequency: 7
    Reset counter: 138
    Mileage: 103555 km
    Time Indication: 0
    Date: 2008.01.28
    Time: 20:59:25
    I can see it is a problem with the rear mid left, does this mean a new sensor is need?
    Anyone experienced this
    Thanks in advance Matt
    S3Ibis White
    Factory RNE-E : Optics : Light/rain sensor : ILP : BOSE : Bluetooth : iPod : Privacyglass : FCA : Auto Dimming/folding mirrors : Park assist
    Mods RS6 grill : Buckets : 19" Bentleys : KW v3 coilovers : H&R ARB's : Autotech HPFP : Milltek TBE : RS6 FBMFSW : Facelift taillights & diffuser : TT vents : ITG Intake : Forge DV : SDS : Alpine ipod kit : Lamin-X : Revo stage2+ : Sachs clutch : Shortended Tailgate : Ibis Colour Coded Interior
    To do FullClosureMirrors
    Vagcom
    Google Adsense Circuit advertisement
    Advertising world
    NIGEL is offline Reverse Gear
    Jan 2007
    16
    Post Thanks / Like
    HI pop the sensors out and swap them over to see that the rear mid left sensor is infact the problem. It could be wiring or bad connection.
    Hope this helps.
