EM TuningDNA Tuning
Thread: ESP Fault code
    Jay
    Jay is offline 2nd Gear
    Aug 2006
    323
    Post Thanks / Like
    ESP Fault code
    Ran Vag com and got the following code.
    Control Module Part Number: 1C0 907 379 E
    Component and/or Version: ESP FRONT MK60 0103
    Software Coding: 0019970
    Work Shop Code: WSC 06435
    1 Fault Found:
    01423 - Lateral Acceleration Sensor (G200)
    012 - Electrical Fault in Circuit
    Ross tech wiki shows the following solutions:
    1. Check Supply Voltage - Does this mean the battery could be weak?
    2. Check Lateral Acceleration Sensor (G200) faulty - Where is the sensor located. I'm hoping it may need a clean as the ESP light flickers when I drive through surface water when its raining?
    3. Perform Lateral Acceleration Sensor (G200) Basic Setting - How is this done?
    thanks
    Google Adsense Circuit advertisement
    TFSI's Avatar
    TFSI is offline Born to Fish
    South Cheshire
    403
    Post Thanks / Like
    Had an intermittent ESP fault myself a while back and it was caused by a dodgy engine speed sensor that initially was not showing a fault.
    When the speed sensor did generate a fault the rpm was surging like hell and ESP was lit all the time.
    New sensor job sorted.
    Jay
    Aug 2006
    323
    Post Thanks / Like
    How much did that set you back? and was it a diy install job?
    TFSI's Avatar
    South Cheshire
    403
    Post Thanks / Like
    Quote Originally Posted by Jay
    Roadside repair under warranty. Works car park to be exact.
    The RAC lad Andy went straight to it and it was sorted in no time
    Excellent service
