ESP Fault code
Jay
NULL
Ran Vag com and got the following code.
Control Module Part Number: 1C0 907 379 E
Component and/or Version: ESP FRONT MK60 0103
Software Coding: 0019970
Work Shop Code: WSC 06435
1 Fault Found:
01423 - Lateral Acceleration Sensor (G200)
012 - Electrical Fault in Circuit
Ross tech wiki shows the following solutions:
1. Check Supply Voltage - Does this mean the battery could be weak?
2. Check Lateral Acceleration Sensor (G200) faulty - Where is the sensor located. I'm hoping it may need a clean as the ESP light flickers when I drive through surface water when its raining?
3. Perform Lateral Acceleration Sensor (G200) Basic Setting - How is this done?
thanks
Had an intermittent ESP fault myself a while back and it was caused by a dodgy engine speed sensor that initially was not showing a fault.
When the speed sensor did generate a fault the rpm was surging like hell and ESP was lit all the time.
New sensor job sorted.
How much did that set you back? and was it a diy install job?
Roadside repair under warranty.:yes: Works car park to be exact.:yes:
The RAC lad Andy went straight to it and it was sorted in no time :yes: :yes:
Excellent service
962
2K
2K
2K
712
