DNA TuningDTUK
    KRL's Avatar
    KRL
    KRL is offline 3rd Gear
    Jul 2007
    523
    Post Thanks / Like
    Window motor fault codes
    Hi,
    My car is showing the following faults agains the driver and passenger windows:
    42-Door Elect, Driver -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.LBL
    Part No: 8P0 959 801 H
    Component: Tuer-SG 020 0090
    Coding: 0000760
    Shop #: WSC 06435
    1 Fault Found:
    00932 - Electric Window Motor; Drivers Side (V147)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.LBL
    Part No: 8P0 959 802 H
    Coding: 0000760
    Shop #: WSC 06435
    1 Fault Found:
    00933 - Electric Window Motor; Passenger Side (V148)
    Both widows are working ok. Does anyone have some further information on what these mean?
    Thanks in advance.
    Ice Silver S3 + every single option + REVO + BSH Street Can + Forge Twintake + Autotech
    Google Adsense Circuit advertisement
    Gti Jazz Blue's Avatar
    Gti Jazz Blue is offline 6th Gear
    Feb 2007
    Hampshire
    1,538
    Post Thanks / Like
    Battery been off recently ?
    I suspect that it is telling you that the once touch open / close needs to be calibrated.
    Hold the down until the window is full open then a few more seconds and then do the oposite.
    Make sure that the one touch operation works on both windows and then see if the codes have gone.
    Regards,
    Paul
    2005 Black A3 (8P1) S-Line 2.0TDi DSG (Ex-MarriedBlonde). Eibach Pro Springs, Koni FSD shocks and a few bling bits inside. HEX-USB+CAN Vag-Com. Gone but not forgotten - Revo 99 GTi Turbo, too much to list mod wise. - 92 Golf Gti Mark 2 16V.
    KRL's Avatar
    KRL
    Jul 2007
    523
    Post Thanks / Like
    Thanks, I'm pretty sure the one touch operation is working. I'll give it a go tomorrow.
    KRL's Avatar
    KRL
    Jul 2007
    523
    Post Thanks / Like
    Yep the one touch operation is working ok.
