17069 - ECM Power Relay Control Circuit
Arvo,
just ran a quick check and got the following back
Thursday, 13 December 2007, 10:58:00
VAG-COM Version: Release 409.1-S
Control Module Part Number: 8N0 906 018 BH
Component and/or Version: 1.8L R4/5VT 0001
Software Coding: 10710
Work Shop Code: WSC 13365
Additional Info: WAUZZZ8L721017033 AUZ7Z0A2027901
9 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17069 - ECM Power Relay Control Circuit (J271): Open
P0685 - 35-10 - - - Intermittent
16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
P0238 - 35-10 - - - Intermittent
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-10 - - - Intermittent
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
16497 - Intake Air Temp. Sensor (G42): Signal too High
P0113 - 35-10 - - - Intermittent
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
17931 - Crash Signal from Airbag Controller: Implausible Signal
P1523 - 35-10 - - - Intermittent
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - - Intermittent
I have cleared them and about to go out for a drive then rescan. I'm pretty much happy with most of them but I can't find this one:
Have checked the Ross bible and googled but nothing; Any ideas?
Jester
"On my second S3 and loving it. RS3 here I come!!!"
