Morning!![]()
I had a few problems with my car over the weekend, alarm going off for no aparent reason, and then the key fob not turning it off or unlocking the car.
Turned out to be a flat battery in the car, but i scanned it with vag com (v711.0 beta) anyway, and came up with the following faults:
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Address 01: Engine Labels: 06A-906-032-AUM.lbl
Part No: 06A 906 032 FC
Component: 1.8L R4/5VT 0001
Coding: 11500
Shop #: WSC 06435
3 Faults Found:
17545 - Fuel Trim: Bank 1 (Add): System too Rich
P1137 - 35-10 - - - Intermittent
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
17072 - ECM Power Relay Load Circuit: (J271): Open Circuit
P0688 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 16202
Shop #: WSC 06435
8 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
01134 - Alarm Horn (H12)
76-00 - Terminal 30 missing
77-00 - Internal Supply Voltage
49-10 - No Communications - Intermittent
I am aware of the first 2 engine codes, and am looking into them, the third i assume was part of my problem with the battery running flat (but it hasn't done it since), and possibly jump starting?
On the central locking/alarm codes, i havent been able to find any details on the ross tech wiki for 01134.
Could this be related to the occasional 4 beeps i get, that means that i need to replace the alarm backup battery? Its the Missing terminal 30 that slightly concerns me.
Any help very much appreciated!
Thanks![]()
LinkBack URL
About LinkBacks
