Backdraft MotorsportDTUK
    killa_z's Avatar
    killa_z is offline Couped Out
    Aug 2006
    London
    175
    Post Thanks / Like
    possible fault code?
    i removed and unplugged my glovebox and then refitted it and once done, the airbag light is constantly showing on my clock cluster on my dash
    i was told that because the airbag switch is in the glovebox (keyhole) when i removed it and refitted it, the computer has registered a fault code and that there is no real problem and just a confusion
    i have a friend coming over with vagcom in a couple days, i have no idea on how to check these things and clear them, any advice is greatly appreciated
    thanks
    DID have...
    2004 Audi A3 3.2 V6 Quattro
    Metallic Black with full Red Nappa Leather
    Full Votex Audi Factory Fitted Body Kit
    most extras.....
    NOW have...
    2007 Audi A5 Sport 3.0TDI Quattro
    Phantom Black with full Black Milano leather
    Big 19's
    almost every extra possible!
    Google Adsense Circuit advertisement
    Advertising world
    marms's Avatar
    marms is offline 4th Gear
    Jan 2007
    Lincolnshire
    837
    Post Thanks / Like
    Just be carefull because with the light on the airbags are disabled!
    If your friend is coming over and has VAG-COM there should be no problem clearing the problem.
    It is simply a matter of connecting to the AirBag controller and checking for errors. Then clear the error. Very obvious when you are sat in the car with a laptop on your knee.
    For the future, you can avoid this code by using the key to disable the passenger airbag. Then turn the ignition on and off again so the car registes that the airbag is disabled. Then remove the glovebox.
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
