W8 PerformanceDTUK
Results 1 to 9 of 9
Thread: bt and vagcom
    quattrov6tdi is offline Neutral
    Oct 2007
    cork ,ireland
    52
    Post Thanks / Like
    bt and vagcom
    does any one out there no why my vagcom cant find my bt kit
    no response from controllor
    a4 v6 2.5tdi b6 18"rs rns-e genuine bt quattro chipped to 210hp mfsw
    Google Adsense Circuit advertisement
    Advertising world
    bearthebruce's Avatar
    bearthebruce is offline Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    277
    Post Thanks / Like
    Early on we had some troubles with the BT modules but thought we had those corrected. Mind telling me what version of VAG-COM you are running?
    How do I know about the troubles? We mod'd my '06 A4 to add the BT capability such that we could check it out and fix the problem. That was 2 years ago and as far as I know, we have not had trouble since.
    It would be good for you to tell me what kind of interface you have, the version of VAG-COM you are running and so on. The more info you provide the more likely we will be able to assist. An auto-scan would also be helpful.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    Oct 2007
    cork ,ireland
    52
    Post Thanks / Like
    vag com details
    hi bruce
    here are the details
    vag com 704.1
    data version 2007 1016
    when i run the auto scan when gets to 77 telephone
    it says no response from controller
    im using the controller from alexia
    Issac Hunt is offline 5th Gear
    Jan 2007
    Hampshire
    1,150
    Post Thanks / Like
    Are you using a genuine HEX-CAN-USB lead?? Can it connect to all other controllers on your car without problems?
    A6 3.0 TDI.
    Sebastian is offline 1st Gear
    Aug 2006
    Magdeburg, Germany
    285
    Post Thanks / Like
    Quote Originally Posted by quattrov6tdi
    Who/what is Alexia? Retrofitted I assume? What's the part number of the control module you are using? In case it's a retrofit, who is the vendor of the wiring you were using? Have you checked he wiring for continuity to the diagnostic port? What VAG-COM interface are you using?
    Please try if the latest Beta 711 makes a difference.
    http://www.ross-tech.com/vag-com/dow...a/current.html
    Sebastian @ Ross-Tech.com
    Oct 2007
    cork ,ireland
    52
    Post Thanks / Like
    bt
    i am using the genuine HEX-CAN-USB sorry i bought from ilexa.co.uk not alexa. it is retrofitted the bt module cam from satnavsystems.co.uk
    the wiring loom i think had only can high, can low,and k line ,power,earth
    these are what i connected
    hope this helps
    regards
    ciaran
    it does find all other modules
    Aug 2006
    Magdeburg, Germany
    285
    Post Thanks / Like
    There is still one question unanswered...
    ...and one advise too.
    Jan 2007
    Hampshire
    1,150
    Post Thanks / Like
    Is the BT module your using second-hand? Have you ever connected to it previously with VAG-COM?
    If it is second-hand did your vendor code it for an A4? If it is still coded for an A3 I think you will struggle to get communication with it.
    A6 3.0 TDI.
    Oct 2007
    cork ,ireland
    52
    Post Thanks / Like
    bt
    hi seb
    the number on it is 8p0862335k
    regards
    ciaran
