AMD TechnikDTUK
Thread: Faults
    Mickeybhoy67 is offline Neutral
    Feb 2006
    glasgow
    45
    Post Thanks / Like
    Faults
    Hi
    I fitted a new throttle body in my audi a3 sport '98.
    then run
    VAG-COM
    3 FAULTS found :
    00518 - Throttle Position Sensor (G69)
    31-00 - Open or Short to Ground
    01087 - Basic Setting Not Performed
    27-00 - Implausible Signal
    00530 - Throttle Position Sensor (G88)
    31-10 - Open or Short to Ground - Intermittent
    Car is running fine apart from starting it from cold when I turn key it stalls straight away so I need to give a acceleration.
    Any advice or help please???
    Google Adsense Circuit advertisement
    Advertising world
    shineydave's Avatar
    shineydave is offline 5th Gear
    Jan 2006
    Bradford, Yorkshire, UK
    904
    Post Thanks / Like
    sounds like you need to run a throttle body adaptation (TBA) on it, go into measuring blocks, select the group that has the throttle body position in it and then switch to basic settings and follow the instructions.
    don't forget to clear all the faults afterwards
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
