If i go into central convenince and add 1152 will it activate alarm/beep/windows via remote?
AUDI S3 2001 (8L)
AUDI S3 2001 (8L)
No, 1152 is will more likely mess things up What's your current coding?
BTW: déjà-vu...
http://audi-sport.net/vb/showthread.php?t=46429
Sebastian @ Ross-Tech.com
i have no idea,the car is arriving tomorrow and the guy asked if i could sort this out for him.
Use this program, its really easy then
Simon
http://www.kevin-st.co.uk/tt/BaseCode/Basecode.zip
A6 2.5tdi Quattro Sport 180
A6 1.9tdi Avant ................. Gladly missed
A6 2.8 Quattro .................. Sadly missed
Quattro 2.8 Coupe ............. Sadly missed
RNS-E, Audi BT, Phatnoise
why not go into the long coding helper and check the relevant boxes?
2003 A3 8L (the old model) doesn't use a long coding...![]()
sorry, my mistake.
Hi...
There is no central convenience in the 8L model of the A3/S3. How have you managed to do this?
I wanted my alarm to beep on lock/unlock and also ant-hi-jack above 20mph.
Can anyone shed any light on this for me??
many thanks
G
Its on central locking [35] i believe
Easy onced logged into it it should popup with the possible changes. Its easy peasy
Just write down your original coding number so if you mess up you can go back to this
Read the ross-tech wiki and the ross tech manual
Hi....
add the vaule of 1024 to the value you see already there in vagcom. mine was 1163, i think, couldn't quite read the screen properly as a technician was doing it. So in plain english, login to chanel 35 - Central Locks, add the value 1024 to whatever your code happens to be.
1024+xxx=
Thanks Mr.G! Do you know if the above program will work on a 01 S3 8L at all? Or is best to use VAG-COM?
Guys worked on mine (adding 1024 to my coding and it worked a treat!)
Tried to do it to my friends 2000 Pre-facelift S3 and it didn't work?! His coding originaly was 15211 which we changed to 16235 and it didn't workAnyone got any ideas why?
Thanks!
check your car and see what coding is stored now,then see if it matches your friend code (16235) if it does then i dont know what the problem could be.....BUT if it dont change your friend coding to the same as yours !
that should have worked, as it has only changed 1 binary bit in the "config"
Was A3 1.8Ts
Now S3
anyone??![]()
Hey Fran
Uhhhh strange one this isn't it. There MUST be a difference in the software/ECU coding on the Pre-Facelift A3/S3 then. Unless the code that your friend has currently is wrong in the first place.
E-mail Ross Tech to ask if there are fundamental differences between the two. This is the quickest way of telling.
They would possibly give you instructions on how to do the changes. If you've purchased the Vag Com from them that is!
G
ok, so i connected up with vag com, but it says it cant find a controller for central convenience! i tried central locking (35) my code was 01236, so i added 1024 and all it did was show up that my 2 door where open on the dash!!! was able to change it back ok tho. any thoughts?
tell a lie, my code was 15178, changed it and the beep works......the anti hijack doesnt tho!!!
cancel that, just had to add another 32 for anti hijack!
