W8 PerformanceRevo Technik
    karmann is offline Reverse Gear
    Sep 2007
    Post Thanks / Like
    No Brake lights!!
    hi guys and girls..
    my Audi A4 2002 model, has no brake lights, well the thrid light is working,.. and no back up lights,.. one stays on all the time had to remove the bulb,.. i've checked the bulbs and voltage with a multi meter.
    fault codes, 00988, 00987 failure in circut, 01518 failure in circut,..
    only mods i've done is change the headlight bulbs to HID's but this was back at christmas,..
    any ideas,.. before i have to put the car into audi, and call my bank manager
    Google Adsense Circuit advertisement
    Rev-head's Avatar
    Rev-head is offline 6th Gear
    Oct 2004
    Perthshire
    2,949
    Post Thanks / Like
    Put your head down below the brake pedal there will be a plunger type sensor that activates the lights everytime you press brake pedal must be stuck or knackered worth a check
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
    Sep 2007
    Post Thanks / Like
    thanks for that, but the third brake light works!! also tested the switch i have power switchin, also checked with Vag-com, that says the switch is workin in the measuring blocks.
    I've read on the usa forums that you can turn off and on some of the rear lights,.. though coding, Any one know about this?
