Sky InsuranceEM Tuning
    Dec 2005
    london
    188
    Post Thanks / Like
    how do you clear faults?
    i got an airbag fault afgter swapping over a steering wheel?
    how do i clear the code? I'm not very clued up with vag-com!
    any help appreciated
    wallacr's Avatar
    Nov 2003
    241
    Post Thanks / Like
    Quote Originally Posted by shufti
    It should be as stright forward as viewing the fault within that module (eg. Air-bags) and then selecting the clear faults button.
    That said, if you've swapped the steering wheels and perhaps the air-bag too, you may have to change some coding. Not 100% sure on that though, as I haven't swapped a steering wheel myself, although I do plan on a multi-function one at some point.
    Hope you get it sorted.
    Cheers,
    Rich
    Rev-head's Avatar
    Oct 2004
    Perthshire
    2,948
    Post Thanks / Like
    same as above go on to control module for airbags and click on fault codes on that window on the bootom right hand side there is a clear fault code button
    If there are none you need to recode top line of coding think on rosstech site has code think its 12342 then apply .......copy all codes that are shown before just incase something stops working ...lol
    Urq RR
    S2 Coupe...RS2 +
    S2 Avant (slipper wagon spec)
    A4 AVANT TDI
