Auto lock problems
wallacr
Cardiff
Hi All,
I bought a cable from Ross-Tech and used it with Vag-Com to enable the auto lock feature at 15MPH, which worked.
I did this by adding 32 to the number, as the vag-com tool tip thing suggests and it works, but if I stop and unlock the doors to let someone in, the doors don't seem to re-lock when I drive off again.
Is this normal? Or is there something I can do to make it re-lock when I drive off again after manually unlocking?
I've got a 2001 (51 plate) A4 1.9 TDI (130BHP) B6.
Cheers,
Rich
Hi mate
Same on mine
Don't think you can do anything about it
Thanks for replying guys, it's good to know that it's nothing I've done wrong, although it's a shame it can't be sorted. Oh well...
Cheers,
Rich
This does the same on mine, i have programmed the wife's A2 and this re-locks itself after been unlocked.
So the conclusion i have come to is if the central locking is air operated it will only lock once until the ignition is turned off and the car re-started, but if the central locking is electronically operated (as the A2) it will re-lock its self when you set off again without re-starting the car.
Thanks Jimbo.King
It's a shame that there is no work around for this.
