Hi i need some help.
2002 Audi A6 2.5TDI
Two weeks ago i had my rear brake pads and disks replaced at a local garage at a cost of £160 which seemed reasonable.
A few days later the ESP light came on permently and also the car seemed to lurch just as stopping for a split second (A bit like you had either tapped the accelerater or lifted off brakes completely) so I sent back to garage to see if connected to anything simple when doing brakes.
I ran the VAG com diagonosics myself and got the results further below. Car was sent back to Garage who kept for 4 days with various calls into Audi who
suggested most likely a fault with Air Mass Sensor which hopefully would sort but could not guarantee. Additional £216 cost but has not cured.
Garage suggested that I now take to main dealer who's advanced diagnositics may be able to pin point rather than wasting any more on labour etc.
( Great after just spend just shy of £400.)
Any suggestions most welcome.
Someone else on furum suggested resetting ABS ECU but i have no ideas how i go about this.
VAG COM codes before it went and had Air Mass sensor changed was as follows.
VAG-COM Version: Release 409.1-US
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,76
Address 01: Engine
Controller: 8E0 907 401 P
Component: 2.5l/4VTEDC G000AG D09
Coding: 01017
Shop #: WSC 02325
00005059 130 106JC150_1.V79520791287
3 Faults Found:
00741 - Brake Pedal Monitoring
27-00 - Implausible Signal
00575 - Intake Manifold Pressure
08-00 - Control Limit Surpassed
00522 - Engine Coolant Temperature Sensor (G62)
30-10 - Open or Short to B+ - Intermittent
Readiness: N/A
Address 02: Auto Trans
Controller: 01J 927 156 FK
Component: V30 01J 2.5lTDI RdW 3011
Coding: 00001
Shop #: WSC 44552
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-00 - -
Address 03: ABS Brakes
Controller: 4B0 614 517 G
Component: ABS/ESP front 1728
Coding: 06459
Shop #: WSC 00000
1 Fault Found:
P1857 - 35-00 - -
2002 Audi A6 2.5TDI
Address 01: Engine
Coding: 01017
Shop #: WSC 02325
3 Faults Found:
Readiness: N/A
Coding: 00001
Shop #: WSC 44552
1 Fault Found:
P1857 - 35-00 - -
Coding: 06459
Shop #: WSC 00000
1 Fault Found:
P1857 - 35-00 - -
