Badger5VAG Check
    Aug 2006
    41
    Post Thanks / Like
    VAG -COM help required
    I have just purchased VAG-COM and have started using it however I have the following questions:
    I am about to retro fit both RNS-E and Bluetooth phone prep to my 2004 A3 Sport back I have looked at a lot of the sites about recoding and have these questions
    CODING FOR RNS-E
    0x?xx Malfunction Diagnosis should it be 0 or 1 for this model.
    0xxx? Telephone/Telematic which number should I use as I am about to fit Bluetooth.
    0xxxx?x Equipment 1 which number should I use here?
    CODING FOR TELEPHONE PREP
    00xx?xx Installation List what number should I use here?
    Does anybody have the correct coding for my vehicle I have a multifunction steering wheel and cd player located in the glove box, any help regarding the recoding of my vehicle and how to complete it would be gratefully appreciated
    regards
    Andy
    Uwe@Ross-Tech's Avatar
    Oct 2006
    130
    Post Thanks / Like
    This page may be helpful:
    http://wiki.ross-tech.com/index.php/...NS-E%29#Coding
    I know of a 2007 A3 Sportback with factory RNS-E and Bluetooth which might shed some light on the ambiguities there, but unfortunately it's not handy right now. I'll see if I can get a scan from it tomorrow or the next day..
    -Uwe-
    Aug 2006
    Magdeburg, Germany
    286
    Post Thanks / Like
    The car Uwe referred to had a coding of 0209617, but keep in mind that's a US model with Bose sound system.
    Sebastian @ Ross-Tech.com
    Oct 2006
    130
    Post Thanks / Like
    Sebastian is a fastidious collector of Auto-Scans...;-)
    He makes a good point that you can't just use this coding if the car doesn't have a Bose sound sytem, but it should still hed some light on the digits that aren't entirely clear since the RNS-E is factory installed, as is the Bluetooth module in that car.
    -Uwe-
