Adrian S FluxEM Tuning
Thread: ABS logging
    Feb 2007
    Dorset
    20
    Post Thanks / Like
    ABS logging
    Hi guys,
    I have a strange fault where my ESP light comes on at aroung 5000rpm in third gear. And at other times too.
    I have the full VAGCOM kit and there are no fault codes logged.
    So..
    I tried to record wheel speed etc while driving. (Using a passanger I hasten to add.) But connection to the ABS controller fails, it was fine sat still and not logging.
    Any ideas?
    Aug 2006
    Magdeburg, Germany
    286
    Post Thanks / Like
    The ABS control modules usually drop connections between 20-60 km/h for security reasons. This is absolutely normal and you'll experience that with all models and diagnostic tools.
    Even though you have no codes, would you mind posting a complete Auto-Scan from the vehicle in question and also post year, make, model and very important ALL modifications you made.
    Sebastian @ Ross-Tech.com
    Feb 2007
    Dorset
    20
    Post Thanks / Like
    scan and more
    Auto scan attached....
    Car is unmodified, or at least that is what I am told.
    Friday,27,April,2007,18:13:25:23380
    VAG-COM Version: Release 704.0
    Data version: 20070404
    Chassis Type: 8D - Audi A4 B5
    Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    Address 01: Engine Labels: 078-907-551-AZA.LBL
    Part No: 8D0 907 551 D
    Component: 2.7l V6/5VT G 0002
    Coding: 05711
    Shop #: WSC 06325
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 8D0-907-389.LBL
    Part No: 8D0 907 389 E
    Component: ABS/ESP allrad D46
    Coding: 04395
    Shop #: WSC 06435
    Address 08: Auto HVAC Labels: None
    Part No: 8D0 820 043 N
    Component: A4 KLIMAAUTOMAT D57
    Coding: 00061
    Shop #: WSC 06325
    Address 15: Airbags Labels: 8D0-959-655-AI8.LBL
    Part No: 8D0 959 655 J
    Component: Airbag Front+Seite 1001
    Coding: 01106
    Shop #: WSC 06325
    1 Fault Found:
    01212 - Belt Tensioner Igniter; Rear Passenger Side (N197)
    32-10 - Resistance too High - Intermittent
    Address 17: Instruments Labels: 8Dx-920-9xx-17.LBL
    Part No: 8D0 920 980 B
    Component: B5-KOMBIINSTR. VDO D11
    Coding: 01462
    Shop #: WSC 00000
    Component: AUZ7Z0Y1434489
    ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0Y1434489
    Address 25: Immobilizer Labels: None
    Part No: Bitte Adress
    Component: e 17 eingeben
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 35: Centr. Locks Labels: 8D0-862-257.LBL
    Part No: 8D0 862 257 E
    Component: CV-Pump, Alarm, RC D13
    Coding: 15178
    Shop #: WSC 06325
    Address 45: Inter. Monitor Labels: 4B0-951-173.LBL
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00102
    Shop #: WSC 06325
    Address 55: Xenon Range Labels: 4B0-907-357-AUT.LBL
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00012
    Shop #: WSC 06325
    Address 56: Radio Labels: None
    Part No: 4B0 035 186 E
    Component: Radio 0001
    Coding: 00205
    Shop #: WSC 06325
    End --------------------------------------------------------------------------------------------------
    Also I have a log file with lots of engine detail boost MAF etc when the fault happens but can see no problems.
    I can send this to anyone by mail if they can help.
