Can my ecu be recoded with vag com NOT to communicate with the following controllers in the log below to prevent the fault codes(18053-18057-01324-01310)...Bear in mind that the engine and ecu were previously in a Allroad 4x4 and now in my A4 FWD..Engine type is A.R.E. These codes will not clear with vag-com and are a constant PITA...Thanks for any help guys.
VAG-COM Version: Release 409.1-S
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 4Z7 907 551 B
Component: 2.7l V6/5VT 0003
Coding: 10812
Shop #: WSC 00535
WAUZZZ4BZ1N031770 AUZ7Z0Y1496807
2 Faults Found:
18053 - Powertrain Data Bus: Missing Message from AWD Controller
P1645 - 35-00 - -
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 35-00 - -
Readiness: 0110 1101
Address 03: ABS Brakes
Controller: 4D0 907 379 D
Component: ABS BOSCH 5 7402
Coding: 0265108005
Shop #: BB 37402
No fault code found.
Address 08: Auto HVAC
Controller: 8D
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 4Z7 920 980
Component: C5-KOMBIINSTR. VDO D13
Coding: 00464
Shop #: WSC 00183
3 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to B+
01324 - Control Module for All Wheel Drive (J492)
49-00 - No Communications
01310 - Level Control System Control Module (J197)
Address 25: Immobilizer
Controller: Bit teA dre ss
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
End --------------------------------------------------------------------------------------------------
Address 01: Engine
Coding: 10812
Shop #: WSC 00535
2 Faults Found:
P1645 - 35-00 - -
P1649 - 35-00 - -
Coding: 0265108005
Shop #: BB 37402
Controller: 8D
Coding: 00464
Shop #: WSC 00183
3 Faults Found:
No Faults Found
