UnicornVAG Check
    MJCAUDI's Avatar
    Jul 2003
    Glasgow
    36
    Post Thanks / Like
    Supply Voltage B+
    Got this error message on vag.com ;
    1 Fault Found:
    00532 - Supply Voltage B+
    53-10 - Supply Voltage Too Low - Intermittent
    Had a new battery a while back. In Bentley it says the problem could be regulator. Does anyone know where the regulator is?
    Fault has not caused any symptoms but keeps returning.
    Aug 2006
    Magdeburg, Germany
    286
    Post Thanks / Like
    Which control module showed that code? Only one module or more?
    Sebastian @ Ross-Tech.com
    MJCAUDI's Avatar
    Jul 2003
    Glasgow
    36
    Post Thanks / Like
    Just the one module,
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
    Part No: 8E0 907 279 C
    Component: int. Lastmodul RDW 0203
    Coding: 00001
    Shop #: WSC 63351
    Aug 2006
    Magdeburg, Germany
    286
    Post Thanks / Like
    Then ignore it for now. The regulator/generator is normally not at fault if only one module triggers that code, now if more than one come up like that then you should start to worry. If a single module comes up with such a code regularly you should start checking the control module connectors and ground spots first.
