KowalskiAWEsome GTI
    vw754's Avatar
    vorsprung Durch Technik
    Nov 2006
    U.K
    1,412
    Post Thanks / Like
    temp gauge readings vag-com
    Had my car on vag-com and when tempreature gauge on dash was reading 90 on vag -com check its showing 80 is this normal or does i need to change the thermostat?
    A4 TDI 130 AWX ENGINE.............NEW COOLANT SENSOR FITTED.......IS IT TIME FOR A THERMOSTAT....????????
    Uwe@Ross-Tech's Avatar
    Oct 2006
    130
    Post Thanks / Like
    The gauge on the dash is not linear at all. Many years ago when it was, too many customers complained about the fluctuations they saw, so VW redesigned the gauges to point at 90C over a wide range of temperatures which are considered to be within the normal operating range.
    -Uwe-
