Volks AutosEM Tuning
    terrymcg's Avatar
    Nov 2006
    West Lothian
    236
    VagCom Faults, advice needed.
    Hi,
    Can any guru tell me what causes these faults and how to rectify them:
    VAG-COM Version: Release 607.3-UD
    Control Module Part Number: 8P0 959 801 H
    Component and/or Version: Tuer-SG 020 0090
    Software Coding: 0000632
    Work Shop Code: WSC 06314
    1 Fault Found:
    00932 - Electric Window Motor; Drivers Side (V147)
    005 - No or Incorrect Basic Setting / Adaptation Intermittent
    Control Module Part Number: 8P0 959 802 H
    1 Fault Found:
    00933 - Electric Window Motor; Passenger Side (V148)
    Control Module Part Number: 1K0 907 530 G
    Component and/or Version: J533__Gateway H10 0140
    Software Coding: 7F0F074007000101
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 240
    Mileage: 18549 km
    Time Indication: 0
    Date: 2007.02.04
    Time: 16:33:36
    Sunday,04,February,2007,16:46:22
    Gateway Installation List: 1K0 907 530 G
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Not registered 0001
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    57 Plate Imola Yellow S3
    bearthebruce's Avatar
    Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    331
    You can find at least some of the codes on the Ross-Tech Wiki. Take a look here:
    http://wiki.ross-tech.com/index.php/...ry:Fault_Codes
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    Uwe@Ross-Tech's Avatar
    Oct 2006
    130
    A registered user could e-mail Support@Ross-Tech.com and get detailed instructions for fixing the CAN Gateway and Navigation issues.
    -Uwe-
    terrymcg's Avatar
    Nov 2006
    West Lothian
    236
    Got it sorted now guys!
    Thanks!
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    care to share the solution with the rest of the forum?
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
