i would like to check if my cars fuel injector is faulty(i.e injector dribble) how can i check this via vag-com and how will i tell which injector this is?
A4 TDI 2001(B6) AWX ENGINE.
You can't do a dribble test with a scan-tool.
What you may want to look at are the measuring blocks (I think 013 and 014) which show the balance between injectors at idle.
-Uwe-
when i go into measuring blocks,how will i know which injectors not running as it should,thanks. how will i know which injectors ok?
Just go to Group 013 and tell us what you have there.
Post your ECU's part number too.
-Uwe-
ECU: 038 906 019 FP
0 281 010 729
These are what i got (cyl 1) -0.75 (cyl 2) -0.42 (cyl 3) 0.66 (cyl 4) 0.52
These figure obviously increase/decrease slightly (taken on idle)
Nothing wrong with those values -- i.e. they don't point at a problem with any particular injector. In fact, they're quite good. Spec is between -2.8 and +2.8.
-Uwe-
A great help,cheers!
