JuicyUnicorn
Results 1 to 9 of 9
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,042
    Post Thanks / Like
    help on logging blocks on 1.8T 96
    hiya can anybody help me do a log on my car
    i need to log the following
    lamda
    air
    spark
    and adv+ timing
    can anybody tell me how i do a log and which blocks i need to log cheers
    TGS-Tuning : TopGear Stockport : Longlife Exhausts Stockport : Turbo-Smart
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,042
    Post Thanks / Like
    ok i found out which block to log for the maf 002 or 003
    still looking for which blocks i need for
    timing
    spark and o2
    Uwe@Ross-Tech's Avatar
    Oct 2006
    130
    Post Thanks / Like
    What's your ECU's VAG part Number?
    -Uwe-
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,042
    Post Thanks / Like
    unsure i will have alook tomorrow why do you need this?
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,042
    Post Thanks / Like
    the part number for the ecu is 8D0 907557 does this help
    Oct 2006
    130
    Post Thanks / Like
    This may be of some help:
    VAG-COM Label file for AEB Engine
    (Right-click to download)
    -Uwe-
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,042
    Post Thanks / Like
    will this label file be already installed in vagcom or will i need to do this myself
    from whats on the file is the same as what comes up on vag.
    im trying to take these reading so i can make a base map for a standalone ecu
    Oct 2006
    130
    Post Thanks / Like
    Depends what version of VAG-COM you're using. If you have the current one (607.3) then it's already there.
    -Uwe-
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,042
    Post Thanks / Like
    cheers mate thanks for your help
