JuicyBadger5
    ibzuk.com is offline Reverse Gear
    Nov 2006
    12
    Post Thanks / Like
    INSTRUMENT CLUSTER ADAPTION ON PASSAT 02
    HI CAN ANYBODY HELP IM USING VAG COM V512.4 IVE GOT ALL CODES SKC FROM BOTH OLD AND THE BRAND NEW CLUSTER, I GO INTO CH 50 ENTER THE 7DIGIT CODE FROM THE ORIGINAL CLUSTER AS ROSS TECH ADVISES TO DO SO THEN I PRESS TEST THEN IN THE TOP LEFT BOX IT SAYS WAIT AFTER A COUPLE OF SECONDS IT SAYS IN TOP LEFT BOX KEY THEN THE NEXT BOX IT SAYS NOT OK THEN NEXT BOX N/A NEXT BOX N/A AND THE SAVE IS HIGHLIGHTED THEN I SAVE BUT THEY DONT ADAPT THE CHASIS NO DONT COME ACROSS TO THE CLUSTER.THANKS IN ADVANCE
    Google Adsense Circuit advertisement
    bearthebruce's Avatar
    bearthebruce is offline Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    277
    Post Thanks / Like
    May I suggest you update to 607.3? We think that should solve the problem.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    Nov 2006
    12
    Post Thanks / Like
    just tried to upgrade to 607.3 wen i test the lead all ok but wen i connect to car its says interface not ready etc.works perfect on 512.4
    Santos_V's Avatar
    Santos_V is offline Reverse Gear
    Nov 2006
    7
    Post Thanks / Like
    Did you go into options and perform the test for your port? Did you update the interface fimware? Vag-com will prompt you with a button to update the firmware. Click the update and you should be all set to go.
    Nov 2006
    12
    Post Thanks / Like
    thanks but there is a problem with the lead ive just spoken to uwe @ ross tech. all being sorted new lead will be with me tommorow.
