Badger5DTUK
Thread: help please
    nick1973's Avatar
    nick1973 is offline Neutral
    Nov 2006
    97
    Post Thanks / Like
    help please
    got car running but now have these faults have changed passenger, driver airbags driver , passenger belt tensoners and drivers side rear tensioner any ideas
    air con not piped up yet
    not bothered about speaker
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
    Address 03 -------------------------------------------------------
    Controller: 1C0 907 379 M
    Component: ESP FRONT MK60 0102
    Coding: 0019970
    Shop #: WSC 06435
    No fault code found.
    Address 08 -------------------------------------------------------
    Controller: 8L0 820 043 K
    Component: A3 KLIMAAUTOMAT 0105
    Coding: 00044
    Shop #: WSC 06435
    2 Faults Found:
    00779 - Outside Air Temp Sensor (G17)
    30-00 - Open or Short to B+
    00792 - A/C Pressure Switch (F129)
    31-00 - Open or Short to Ground
    Address 15 -------------------------------------------------------
    Controller: 8L0 959 655 L
    Component: Airbag Front+Seite 7008
    Coding: 01104
    Shop #: WSC 06435
    5 Faults Found:
    00588 - Airbag Igniter: Driver Side (N95)
    32-10 - Resistance too High - Intermittent
    00654 - Seat Belt Tensioner Igniter: Driver Side (N153)
    01211 - Belt Tensioner Igniter: Rear Driver Side (N196)
    36-10 - Open Circuit - Intermittent
    01228 - Airbag Cut-Off Switch for Passenger Side (E224)
    30-10 - Open or Short to B+ - Intermittent
    00532 - Supply Voltage B+
    07-10 - Signal to Low - Intermittent
    Address 17 -------------------------------------------------------
    Controller: 8L0 920 980 N
    Component: KOMBI+WEGFAHRS. VDO D11
    Coding: 04440
    Shop #: WSC 00452
    WAUZZZ8LX3A082475 AUZ7Z0C2318592
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    53-10 - Supply Voltage Too Low - Intermittent
    Address 35 -------------------------------------------------------
    Controller: 8D0 862 257 E
    Component: CV-Pump, Alarm, RC D17
    Coding: 15178
    Shop #: WSC 06435
    9 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch: Driver's Side
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01368 - Alarm triggered by Luggage Compartment Switch
    35-00 - -
    01366 - Opened Due to Crash Signal
    35-00 - -
    01389 - Tailgate Open Switch (F124)
    29-00 - Short to Ground
    00955 - Key 1
    09-00 - Adaptation Limit Surpassed
    01134 - Alarm Horn (H12)
    49-10 - No Communications - Intermittent
    Address 45 -------------------------------------------------------
    Controller: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 00000
    2 Faults Found:
    01380 - Alarm triggered by Anti-Theft Sensor: Rear Left
    35-00 - -
    01381 - Alarm triggered by Anti-Theft Sensor: Rear Right
    35-00 - -
    Address 56 -------------------------------------------------------
    Controller: 8L0 035 195 H
    Component: symphony II NP2 0151
    Coding: 00001
    Shop #: WSC 00415
    1 Fault Found:
    00879 - Connection to Speaker Front Right
    End -------------------------------------------------------
    Google Adsense Circuit advertisement
    shineydave's Avatar
    shineydave is offline 5th Gear
    Jan 2006
    Bradford, Yorkshire, UK
    904
    Post Thanks / Like
    have you tried clearing them, which ones come back?
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
