When i bought my A4 B6 it only came with one key.
I bought a key for my year and model from eBay and the guy assured me it would have the right transponder in it for my car and that all i needed is to get it cut.
Once cut and i stick it in the door and the original remote i the ignition and do the programming it should work right?
However, after looking at VAG-COM Wiki i found this:
Does this mean i have to program the key to the car via this method? Does this automatically pick-up the key, to remote unlock and lock?
[QUOTE]
Channel 021: Remote Control Matching
[Select]
[46 - Comfort System]
[Adaptation - 10]
Channel 021.
[Read]
Choose the memory position you want the new key be matched on by entering it's number (e.g. "3" for memory positon 3).
[Test]
Now press any button on the remote you want to match.
The meas. block field above will change from Not Recogn. to Recognized.
[Save]
[Done, Go Back]
[Close Controller, Go Back - 06]
Note: You can check the current memory positions using Meas. Block 007.
[\QUOTE]
LinkBack URL
About LinkBacks
