AWEsome GTIDNA Tuning
Results 1 to 7 of 7
    Haroulli's Avatar
    Haroulli is offline Neutral
    Jun 2006
    East Coast USA
    31
    Post Thanks / Like
    Any Good VAG-COM Information for B6 A4?
    Ive used VAG-COM before on my old MkIV GTi but i guess different cars are different.
    Ideally i want to get my fog lights to run with my little side lights. This is the information Ross-Tech gives me:
    09-Elec. Ctrl. Mod. K1 – KWP1281
    VAG-COM works fine.
    Tweak: Coding options for lighting Coding is 000XY.
    X=1 for Xenon Headlights,
    X=0 for conventional Halogens.
    Country DRLs: Fogs w/o low beams:
    Y=1 RDW (Rest of World) No Yes
    Y=2 NDL (Netherlands) Yes Yes
    Y=3 USA No No
    Y=4 KAN (Canada) Yes Yes
    Y=5 DAN (Denmark?) Yes Yes
    Y=6 SON (Other?) Yes Yes
    Fogs w/o low beams only appears to work on 2002 models. For 2003+ models, we know of no way to run the fogs without the low beams, except Canadian, which turns on Daytime Running Lamps (DRL's). We are not sure why there are so many Yes/Yes combinations; there must be some other features controller by this. The state of the Radio and Climate Control lighting is affected by this coding as well.
    However, it does not say where i'm to go to edit it, in VAG-COM's software, I open up 09-Elec. Ctrl. Mod. but then what? Do i need to find the channel? Or do i do a Recode? etc etc.
    Anymore handy options will be much appriciated.
    Google Adsense Circuit advertisement
    Advertising world
    Sebastian is offline 1st Gear
    Aug 2006
    Magdeburg, Germany
    285
    Post Thanks / Like
    Since it says "coding", it should be obvious that this means function 07, which is also called "coding".
    Sebastian @ Ross-Tech.com
    sjokolademelka is offline Neutral
    Oct 2006
    Norway
    37
    Post Thanks / Like
    Now that was rude, Sebastian :P
    Aug 2006
    Magdeburg, Germany
    285
    Post Thanks / Like
    Sorry, wasn't meant that way - hope you don't take it personal.
    BTW: We have updated coding tables for the A4 (8E) in our WIKI:
    http://wiki.ross-tech.com/index.php/...et_%288E/8H%29
    Oct 2006
    Norway
    37
    Post Thanks / Like
    I was merely joking :D
    Sorry for the OT Haroulli..
    Haroulli's Avatar
    Jun 2006
    East Coast USA
    31
    Post Thanks / Like
    Sebastian on my version of VAG-COM its "Recoding"
    Anyways i figured it out
    for my original thinking, i wanted to set my foglights to work with the side lights.
    My software code was set to 0003 so i set it to 0001 to set from USA to Rest of World however it hasn't worked! Still as before!
    Ideas?
    Uwe@Ross-Tech's Avatar
    Uwe@Ross-Tech is offline 1st Gear
    Oct 2006
    129
    Post Thanks / Like
    Perhaps you should consider updating to the current version rather than using an ancient one which which is no longer supported.
    -Uwe-
