Badger5EM Tuning
Thread: Crank sensor?
    rodenal's Avatar
    rodenal is offline 6th Gear
    Oct 2006
    1,982
    Post Thanks / Like
    Crank sensor?
    Car was running like a dog today, spluttering and not revving properly so stuck it on vag com and got the following:
    VAG-COM Version: Release 311.2-N
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
    Address 01 -------------------------------------------------------
    Controller: 06A 906 019 D
    Component: 1.6l R4/2V SIMOS HS2153
    Coding: 04000
    Shop #: WSC 00000
    1 Fault Found:
    00515 - Camshaft Position (Hall) Sensor (G40)
    03-00 - No Signal
    Readiness: N/A
    Address 03 -------------------------------------------------------
    Controller: 1J0 907 379
    Component: ABS ITTAE 20 GI V00
    Coding: 03604
    Shop #: WSC 06435
    No fault code found.
    Skipping Address 15-Airbags
    Address 17 -------------------------------------------------------
    Controller: 8L0 919 910 A
    Component: AB-KOMBIINSTR. VDO D07
    Coding: 08442
    Shop #: WSC 00000
    IMMO-IDENTNR: AUZ7Z0T0031761
    1 Fault Found:
    01176 - Key
    07-00 - Signal to Low
    Address 35 -------------------------------------------------------
    Controller: 8LO 862 257 A
    Component: ZV-Pumpe, DWA
    Coding: 01320
    Shop #: WSC 06313
    Address 45 -------------------------------------------------------
    Controller: 8L0 951 173
    Component: Innenraumueberw. D01
    Coding: 00001
    Shop #: WSC 00000
    End -------------------------------------------------------
    Camshaft position sensor is the only one that concerns me, is this just another name for the crank sensor? Also what does no signal mean, that its bust or that it may have become disconnected?
    The car has this fault intermittently, sometimes it will run rough for a day or two then be fine for months, cleared this same code once 6 months ago and its never came back until now,
    any advice apreciated
    *Gone* 1997 A3 1.6 facelift headlights, 16"1.8t Alloys, full rear tints. 110k
    You built a time machine.........out of a delorean!?!?!
    Google Adsense Circuit advertisement
    bearthebruce's Avatar
    bearthebruce is offline Ross-Tech, LLC
    Jul 2006
    Ambler, PA
    277
    Post Thanks / Like
    It may be bust or it may have a connection problem. No signal means that the ECU is not recieving a signal from the sensor. Since you know it to be intermittent, I would check the wiring and if I could not find a fault there, I would replace the sensor.
    -Bruce-
    Ross-Tech, LLC
    Bruce@Ross-Tech.com
    rodenal's Avatar
    Oct 2006
    1,982
    Post Thanks / Like
    Yeah thats what ill do, next question....
    where is it? lol
    Uwe@Ross-Tech's Avatar
    Uwe@Ross-Tech is offline 1st Gear
    Oct 2006
    129
    Post Thanks / Like
    If the engine has a single coil and a mechanical distributor for the ignition, then it's likely in the distributor.
    If the engine does not have a mechanical distributor, then it will be at one end of the head, near the end of a camshaft.
    -Uwe-
