sjokolademelka
Hello fellas,
We just recently autoscanned my friends car with vagcom just to check for faults (at this time the airbag light was not on).
We then made a log, cleared all faults, which was resistance errors at airbag module and alarm triggered by interior sensor error.
However, after we cleared the DTC's the airbag light now lights up and shows the same 5 faults.. while trying to clear it it still comes back right away. Anyone has got any ideas what can be wrong? A little weird that all of the airbag moduls have resistance problems so I wonder if this is caused by something else?
Anyone, please??
First scan:
Saturday,16,December,2006,12:45:42
VAG-COM Version: Release 607.3-UD
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Address 01: Engine
Part No: 06A 906 018 CJ
Component: 1.8L R4/5VT MOTR HS D01
Coding: 04000
Shop #: WSC 06435
No fault code found.
Readiness: N/A
Address 03: ABS Brakes
Part No: 1J0 907 379 Q
Component: ABS/EDS 20 IE CAN 0001
Coding: 13504
Shop #: WSC 06435
Address 08: Auto HVAC
Part No: 8L0 820 043 M
Component: A3 KLIMAVOLLAUTOMAT_D77
Coding: 03140
Shop #: WSC 06435
Address 15: Airbags
Part No: 8L0 959 655 J
Component: Airbag Front+Seite 3008
Coding: 00104
Shop #: WSC 06435
5 Faults Found:
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
32-00 - Resistance too High
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
01218 - Side Airbag Igniter; Passenger Side (N200)
01217 - Side Airbag Igniter; Driver Side (N199)
00588 - Airbag Igniter; Driver Side (N95)
Address 17: Instruments
Part No: 8L0 920 900 C
Component: AB-KOMBIINSTR. VDO D11
Coding: 00144
Shop #: WSC 00000
Component: AUZ7Z0Y1482647
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0Y1482647
Address 35: Centr. Locks
Part No: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D11
Coding: 15178
Shop #: WSC 06435
4 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
End --------------------------------------------------------------------------------------------------
Second scan:
Saturday,16,December,2006,13:30:47
Address 01: Engine
Coding: 04000
Shop #: WSC 06435
Readiness: N/A
Coding: 13504
Shop #: WSC 06435
Coding: 03140
Shop #: WSC 06435
Address 15: Airbags
Coding: 00104
Shop #: WSC 06435
5 Faults Found:
32-10 - Resistance too High - Intermittent
Coding: 00144
Shop #: WSC 00000
Coding: 15178
Shop #: WSC 06435
Coding: 00001
Shop #: WSC 00000
Anyone, please??
First scan:
Address 01: Engine
Coding: 04000
Shop #: WSC 06435
Readiness: N/A
Coding: 13504
Shop #: WSC 06435
Coding: 03140
Shop #: WSC 06435
Address 15: Airbags
Coding: 00104
Shop #: WSC 06435
5 Faults Found:
Coding: 00144
Shop #: WSC 00000
Coding: 15178
Shop #: WSC 06435
4 Faults Found:
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00001
Shop #: WSC 00000
Second scan:
Address 01: Engine
Coding: 04000
Shop #: WSC 06435
Readiness: N/A
Coding: 13504
Shop #: WSC 06435
Coding: 03140
Shop #: WSC 06435
Address 15: Airbags
Coding: 00104
Shop #: WSC 06435
5 Faults Found:
Coding: 00144
Shop #: WSC 00000
Coding: 15178
Shop #: WSC 06435
Coding: 00001
Shop #: WSC 00000
