You can graph boost pressure as follows:
Go to Engine Measuring Block 011
Start Logging the data
In a high gear (4th/5th) give full throttle from 1500-2000 rpm to 3500-4000 rpm
Find and Open the Log file in Windows Explorer
In Excel graph actual/requested boost -vs- rpm
On a stock vehicle, one should see a spike at 2.1 bar quickly regulated at 1.9 through the whole rpm range
You only need a basic laptop which is cabable of running Windows '95 comfortably and which is equipped with a serial port 9-pin (d-type).
There are 5 packages available to suit all budgets, all of which include the full version of the Ross-Tech VAG-COM software.
Package 1
Standard OBD2 Cable with VAG-COM software
For use with all vehicles featuring the DLC connector except 2002 onward model year A4 & A8
Package 2 Pro-2 OBD2 Cable with VAG-COM software
Features LED to indicate connection status.
Package 3
K1-K2 (Twin Com) OBD2 Cable with VAG-COM software
Features twin LEDs to indicate connection status (line one & line two)
For use with all vehicles featuring the DLC connector including 2002 onward model year A4 & A8
Package 4
Pro-2 OBD2 Cable and VAS 5051/2 adapter with VAG-COM software
For use with all vehicles including earlier models featuring the 2x2 connector, but excluding 2002 onward model year A4 & A8
Package 5
K1-K2 (Twin-com) OBD2 Cable and VAS 5051/2 adapter with VAG-COM software
All cables are German manufactured and come with a 2-year manufacturers warranty.
Please see the VAG-COM products page for pricing details.
Best wishes,
Ram®
LinkBack URL
About LinkBacks
2002 Audi S3
