DNA TuningJuicy
    Passatman is offline Reverse Gear
    Nov 2006
    19
    Post Thanks / Like
    Question VAG-COM & MAF & More...
    Hi there
    (Sebastian, this is pretty much addressed to you....oh, and just spent a lot of ZAR ((South African currency LOL)) on a HEX USB - your fault of course! Looks like a very useful "tool".
    1.Replaced the previously faulty MAF and it is reading within the stated spec...and climbs as you rev the engine, however seems no difference in performance, although don't want to thrash it just yet...Upsolute chipped and freeflow exhaust, would that make a difference or does the ECU have to "learn" the fact that the MAF now works after about 2 months?
    2. Also, I get this fault code, not sure how to tackle it?
    Address 08: Auto HVAC
    Part No: 3B2 907 044 J
    Component: CLIMATRONIC B5GP 0004
    Coding: 17000
    Shop #: WSC 00028
    1 Fault Found:
    01274 - Air Flow Flap Positioning Motor (V71)
    37-00 - Faulty
    Help would be most welcome..!
    Google Adsense Circuit advertisement
    Uwe@Ross-Tech's Avatar
    Uwe@Ross-Tech is offline 1st Gear
    Oct 2006
    129
    Post Thanks / Like
    1) Did you clear fault codes after installing the new MAF? Doing so resets the fuel trims and other learned values and gives you a fresh start.
    2) I suspect there's a lot of tearing apart of the dash needed to get to that motor. If the HVAC still works to your satisfaction, I'd ignore that one.
    -Uwe-
    Nov 2006
    19
    Post Thanks / Like
    MAF & Other
    Hi Uwe
    Yes, I did clear the fault codes. Guess it just has to learn a bit?
    The aircon seems to work fairly ok, just when you set it to recirculate (to keep smoke etc out when necessary), it does not seem to seal off the car from outside.
    dultanur's Avatar
    dultanur is offline all promises, no action :)
    Sep 2006
    Istanbul,Turkey
    407
    Post Thanks / Like
    have the same problem. the recirculation flap is beneath the pollen filter. check to see if it works when you press the recirc. button.
    2000 Black S3 (Sold, then totalled) - 2008 A3 1.4T Sport
