JBSAWEsome GTI
    Tinpusher is offline Reverse Gear
    Nov 2006
    Post Thanks / Like
    Can't change SOFT CODE
    Hi
    I'm trying to fit a new instrument cluster to my 2000 A4 2.5 TDI. I've got a 3rd party interface running with VAG-COM 409.1
    I can access all of the modules and even write adaptation changes but for some reason I cannot change a single Soft Code using the Recode-07 feature.
    for example. The soft code for my old cluster is 00460 and the new one is currently 00440. I need to change it to reflect the V6 engine.
    I click recode, enter in the code and then do It, VAG-COM cycles and the returns the old code, not the new one.
    This is also the case when I try to change any Soft Code on any of the modules, even the radio.
    All the other features seem to work and I can make adaptation changes.
    Can anyone help or suggest anything ????
    cheers
    I
    Google Adsense Circuit advertisement
    Nov 2006
    Post Thanks / Like
    Problem Solved
    Seems I had a dodgy version of VAG-COM
    downloaded a new version from the website which works perfectly.
    cheers
    Uwe@Ross-Tech's Avatar
    Uwe@Ross-Tech is offline 1st Gear
    Oct 2006
    129
    Post Thanks / Like
    Just curious, but where did you get this "dodgy" version?
    E-Mail me if you want to answer privately.
    -Uwe- Uwe(at)Ross-Tech.com
