Can't change SOFT CODE
Tinpusher
NULL
Hi
I'm trying to fit a new instrument cluster to my 2000 A4 2.5 TDI. I've got a 3rd party interface running with VAG-COM 409.1
I can access all of the modules and even write adaptation changes but for some reason I cannot change a single Soft Code using the Recode-07 feature.
for example. The soft code for my old cluster is 00460 and the new one is currently 00440. I need to change it to reflect the V6 engine.
I click recode, enter in the code and then do It, VAG-COM cycles and the returns the old code, not the new one. :wtf:
This is also the case when I try to change any Soft Code on any of the modules, even the radio.
All the other features seem to work and I can make adaptation changes.
Can anyone help or suggest anything ????
cheers
I
Seems I had a dodgy version of VAG-COM
downloaded a new version from the website which works perfectly.
cheers:yahoo:
Just curious, but where did you get this "dodgy" version?
E-Mail me if you want to answer privately.
-Uwe- Uwe(at)Ross-Tech.com
