W8 PerformanceJBS
    Passatman is offline Reverse Gear
    Nov 2006
    19
    Post Thanks / Like
    Mass Airflow Sensor
    Hi all,
    I have a 2002 passat 1.8T which has been chipped (Upsolute), Freeflow pipe (didn't want too much nose so went with 57mm and 2 teensy freeflow boxes), and BMC Freeflow Filter.
    I have picked up an error, (Air Mass Sensor, low input).
    I have noticed a very, (almost unnoticeable) stutter at low to medium load conditions.
    Questions:
    1. Are these 2 things related?
    2. Could the (washable )- thus oil coated BMC filter damage the Air Mass Sensor?
    3. Can the Air Mass Sensor be cleaned/what could the problem be?
    Google Adsense Circuit advertisement
    Sebastian is offline 1st Gear
    Aug 2006
    Magdeburg, Germany
    285
    Post Thanks / Like
    1. Probably, yes.
    2. Yes.
    3. It can but cleaning doesn't help in the long run, a new MAF is usually the way to go. Run a full throttle log and check the peak MAF value.
    Sebastian @ Ross-Tech.com
