Hi Uwe,
No, the car is running standard ride height, I considered that too. Since last posting I started considering the mechanical arrangement and have done the following:
1) As the headlight range was low, the controller must be seeing that either the front of the car is high or the rear is low.
2) When the front of the car rises, the arm of the sensor falls, therefore moving the arm up will raise the headlights.
3) The front sensor to suspension arm link rod has a bend in it therefore by partly straightening this bend the headlight aim can be raised.
By doing the above I now have a higher aim on the headlights, however the front sensor is reading below 1 volt, (further out of range than before). If I now jack up the front or rear of the car the lights adjust to compensate to the same level (I have the beam pattern drawn on the inside of my garage door to check against after every journey!).
Maybe the reading from the rear is incorrect although I do not understand how that could be as all the brackets appear standard, the sensor is new and the link rod is straight. The only possibility is if a previous owner fitted a new (incorrect) link rod but I cannot believe that has happened.
It remains a mystery although I can now see to drive in the dark!
Cheers,
Tony
2001 S3|Ebony Black|Revo|MTM Clutch|RS4 Reps|Tarox Brakes
'95 Corrado VR6|Classic Green|Koni/Eibach|Undergoing major rebuild!
