Here is a great list of fault codes over at wikipedia :
http://wiki.ross-tech.com/index.php/...ry:Fault_Codes
This should help you in diagnosing VAG-COM fault codes, if not, just post in this forum and others will be able to help you out !
Hi, can anyone shed any light on what is causing this code? How do I repair it. Can't see any loose connectors or damaged wiring under the seat.
What does upper limit exceeded mean.
Thanks in advance.
Tuesday,30,October,2007,16:36:53:36729
VAG-COM Version: Release 704.1
Address 15: Airbags
Control Module Part Number: 8H0 959 655 B
Component and/or Version: Airbag 8.4EC 2015
Software Coding: 0011104
Work Shop Code: WSC 00672
1 Fault Found:
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Did you follow the link to the Ross-Tech Wiki and read the fault code information found there? The link takes you into the Ross-Tech Wiki where the fault code you are looking to diagnose is listed with symptoms and suggested items to check as possible causes.
http://wiki.ross-tech.com/index.php/01217
VAGCOM code help please?
01367 - Central locking pump run time exceeded.
01305 - databus for infotainment.
What do these mean? and what if any is a soltuion?
Clear them & see if they come back 1st mate, then look at why they're there, guess you found someone to check for you.
Coding, Scanning, Installs, Parts, VCDS Seller
"Live as if you were to die tomorrow, Learn as if you were to live forever"
hi cn any one help with these codes ?
Coding: 00001
Shop #: WSC 63351
2 Faults Found:
01753 - Windshield Wiper Motor (V) Stage 1
31-10 - Open or Short to Ground - Intermittent
01754 - Windshield Wiper Motor (V) Stage 2
any help much appreciated
thx
Cheech
Why are you posting in several threads, just keep it to one thread so the replies remain in the same place, otherwise it gets messy & confusing for others.
16518 - Oxygen (lambda) Sensor B1 S1: No Activity
p0134 - 35 - 10 - - - Intermittent
please help guys what does this mean in dumb dumb terms and what can i do to fix it the lambas brand new
Means you have a dodgy sensor that probably needs replacing.
It would help if you'd given us all this information originally fella, then I would look at wiring if 3rd time now.
Sorry realised that after lol my bad ummm where should I be looking any ideas or suggestions would be great
