Hi,
Have a 2000 S6 4.2 V8 and have just managed my first VAG-COM auto scan.
Have put it below.
There are a couple of little errors which dont look too much to worry about, the last one is the radio but that might be because it was turned on?
Any comments welcome
VAG-COM Version: Release 311.2-N
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56
Address 01 -------------------------------------------------------
Controller: 4D0 907 558
Component: 4.2L V8/5V G 0002
Coding: 05752
Shop #: WSC 02325
No fault code found.
Address 02 -------------------------------------------------------
Controller: 4B0 927 156 BT
Component: AG5 01L 4.2l5V RdW 1314
Coding: 00001
Shop #: WSC 02325
Address 03 -------------------------------------------------------
Controller: 8D0 907 389 F
Component: ABS/ESP allrad D36
Coding: 06397
Shop #: WSC 02325
Address 08 -------------------------------------------------------
Controller: 4B0 820 043 J
Component: A6-Klimavollautomat D64
Coding: 00081
Shop #: WSC 02325
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 4B0 920 980 K
Component: C5-KOMBIINSTR. VDO D09
Coding: 01483
Shop #: WSC 00097
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0X1313582
Address 35 -------------------------------------------------------
Controller: 4B0 962 258 H
Component: Central Lock/Alarm D33
Coding: 05866
Shop #: WSC 02325
1 Fault Found:
01561 - Left Rear Door
60-00 - Won't Safe
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 02325
Address 55 -------------------------------------------------------
Controller: 4B0 907 357 C
Component: dynamische LWR D02
Coding: 00020
Shop #: WSC 02325
Address 56 -------------------------------------------------------
Controller: 4B0 035 186 E
Component: Radio 0001
Coding: 00017
Shop #: WSC 02325
1 Fault Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
End -------------------------------------------------------
