JMB RetrofitsEM Tuning
    May 2014
    Woobridge, Suffolk
    17
    Buying VCDS vag-com
    Hi everyone
    Was thinking of buying some fault code equipment, any recommendations?
    Jan 2011
    Aberdeenshire
    646
    For full VCDS PM NHN on here - he'll happily sell you a genuine cable and give you assistance on here.
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
    May 2014
    Woobridge, Suffolk
    17
    Thanks Paulf, any idea how much I should be spending?
    Jan 2011
    Aberdeenshire
    646
    Depending where you buy, it will be £250 upwards.
    It is a lot of money, but you'll get that back very quickly once you need to diagnose faults.
    VCDS is much more than just a fault code reader - you can enable features, check values log them - the list goes on.
    The sooner into your VAG car ownership you buy it, the better as if you own one and work on it you will buy it eventually!
    The lead will also be compatible with the whole VAG range - so you can bail out your mates too!
  1. Where can i buy VCDS - Vag-Com
    By ilim in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th November 2012, 09:53
  2. Replies: 24
    Last Post: 17th February 2012, 06:13
  3. VCDS (VAG-COM) help needed
    By mdre83 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th March 2010, 16:59
  4. vcds (vag com)
    By hilly in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd November 2009, 09:47
  5. buy a VAG Com for my 8P
    By itssam in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th March 2009, 20:43
