    Oct 2013
    Old Windsor
    9
    A4 B5.5 2.5tdi Avant codes help please
    Scanned my car last night and found the following codes. The car starts first turn, shows 32mpg on the MFA and runs smoothly, however I feel that it is a little flat beyond 3K RPM - I don't feel it picks up when accelerating in gear beyond 3K rpm.
    (I have now cleared these and will rescan in a few days)
    The main ones that I'm interested in are 01442 - misfire, 00523 - Intake Air Temp and 01376 - Engine Speed Signal. I guess the misfire could be related to the low fuel?
    I have noticed a few bubbles in the feed pipe from the filter to the pump and will be replacing the filter and re-crimping the pipe connectors.
    Thanks in advance.
    7 Faults Found:
    00546 - Data wiring faulty
    49-10 - No Communications - Intermittent
    01442 - Misfire due to Lack of Fuel
    35-10 - - - Intermittent
    01441 - Low Fuel Level Sensor (G210)
    27-10 - Implausible Signal - Intermittent
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - Intermittent
    00523 - Intake Air Temp Sensor (G42)
    30-00 - Open or Short to Plus
    01376 - Engine Speed Signal for Injection Pump
    37-10 - Faulty - Intermittent
    00741 - Brake Pedal Monitoring
    27-00 - Implausible Signal
    Jul 2007
    London
    3,207
    What worries me is the fault pointing at the injector pump 01376 as it points at the injector pump being on last legs but could be also caused by prolonged cranking without fuel...
    As for the lack of performance, i would do a boost log if possible, 5th gear from 2000 to 4000 rpms logging measuring blocks 11, 8 and 3... That will show if any issues with your MAF or turbo not meeting the requested boost...
    FOR SALE:
  1. 2.8 Fault code help please
    By stapo69 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th January 2009, 20:54
  2. FAULT CODE HELP PLEASE
    By 1wheelonly in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th November 2008, 07:14
  3. FAULT CODE HELP PLEASE
    By 1wheelonly in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th November 2008, 18:31
  4. engine code help please
    By oadamo in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th September 2007, 18:28
  5. VAGCOM Codes help please!!!
    By Herby1 in forum TT/TT-S/TT-RS Forum
    Last Post: 5th September 2007, 22:37
