EM TuningBadger5
    May 2014
    vcds faults audi a4 1.9 tdi awx problems help
    Can anyone shed some light on something ive never herd of before, and will it make any difference if i just leave it as the car runs fine
    17994 - Engine Mount Solenoid Valves (N144/N145) P1586 - 35-10 - Short to Plus - Intermittent
    also is this a CTS and thermostat problem, it doesnt affect the car running but i notised it when the temp guage was acting wierd sometime not working and other time ok so i loged it to see
    Nov 2013
    Heath Hayes
    951
    Change the Coolant temp sensor, very common fault. The original design ws revised and original sensors are black new ones are green.
    There are two sensors in each temperature sensor. One feeds the ECU one the temperature gauge.
    Sensor is located just under the tandem pump.
    Karl
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    May 2014
    thanks its the 4 pin black original by the looks of it lol
    May 2014
    Quote Originally Posted by A4TDIAWX View Post
    got it fixed new CTS and looking loads better now
    Nov 2013
    Heath Hayes
    951
    Good job, nice cheap simple fix for a change.
  1. Help please - Audi A3 2.0 TDi - alarm problem!
    By hotfuss73 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th April 2014, 17:07
  2. Audi a3 1.6 tdi fuse box help!!
    By Yolo_8p3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th July 2013, 00:05
  3. HELP!! my audi A4 1.9 TDI awx 130 timing belt has ripped teath off and won't fire :(
    By Chrissy a4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th September 2012, 14:15
  4. Audi 2.5 V6 TDI has Died!! Help
    By csmith in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th March 2010, 13:25
  5. 55 Pate Audi A4 2.0 TDI Turbo problem. HELP PLEASE!!!!
    By hronald88 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th September 2009, 19:04
